ESP32 Failed to connect to Espressif device after changing baudrate to 460800
hamza-712
Postby hamza-712 » Tue Mar 14, 2023 9:37 am
I am having trouble connecting to ESP32 after I changed its baudrate to 460800.
System:
Windows 10
I was flashing ESP32-WROOM-32D with micropython firmware.
I had successfully erased flash using
esptool.py --chip esp32 --port COM5 erase_flash
then I ran the following command
esptool.py --chip esp32 --port COM5--baud 460800 write_flash -z 0x1000 esp32-20190125-v1.10.bin
1- It printed changing baudrate to 460800. but after that there was error
Code: Untitled.txt Select all
File "/home/jfcliche/.espressif/python_env/idf5.1_py3.10_env/lib/python3.10/site-packages/esptool/loader.py", line 690, in read_reg
val, data = self.command(
File "/home/jfcliche/.espressif/python_env/idf5.1_py3.10_env/lib/python3.10/site-packages/esptool/loader.py", line 376, in command
p = self.read()
File "/home/jfcliche/.espressif/python_env/idf5.1_py3.10_env/lib/python3.10/site-packages/esptool/loader.py", line 308, in read
return next(self._slip_reader)
StopIteration
2- After this, I am unable to connect to ESP32.
Code: Untitled.bsh Select all
esptool.py -p COM5 -b 115200 erase_flash
esptool.py v3.3.2
Serial port COM5
Connecting......................................
A fatal error occurred: Failed to connect to Espressif device: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
