I am trying to integrate the ESP Insight feature into one of my projects but apparently whenever I am building the project it never recognizes the Insight header file esp_insight.h file I have made all the necessary addition in my root cmake file and my env variable and downloaded the necessary repo but I am unable to build my code
Code: Untitled.cmake Select all
[code]cmake_minimum_required(VERSION 3.16)
if(DEFINED ENV{INSIGHTS_PATH})
set(INSIGHTS_PATH $ENV{INSIGHTS_PATH})
else()
set(INSIGHTS_PATH ${CMAKE_CURRENT_LIST_DIR}/../..)
endif(DEFINED ENV{INSIGHTS_PATH})
# Add RainMaker components
set(EXTRA_COMPONENT_DIRS ${INSIGHTS_PATH}/components ${INSIGHTS_PATH}/examples/common)
set(EXTRA_COMPONENT_DIRS $ENV{IDF_PATH}/examples/protocols/modbus/mb_example_common)
project(Feb_RS485)[/code]Can anyone Help me in identifying the problems ??
