Working with large floating point numbers.
lordreas
Postby lordreas » Tue Mar 14, 2023 11:50 pm
Hello there,
I'm struggling with calculations involving large floats. Running the following code on my Wemos Lolin32 Lite on Arduino featuring an ESP-32 Rev1
Code: Untitled.cpp Select all
double test = 2.;
Serial.begin(31250);
test*=1.1;
Serial.println(test);
leading to the following output after some time:
3741032413.72
4115135655.09
ovf
ovf
ovf
4115135655.09 is way below theoretical limits of float (3e38) let alone double (1e308). What's happening here? I know Esp32 is not the best number for fast or precise FLOPs, but something else but precision seems to be wrong here.
I would be glad if someone could reproduce this / help me / hint me at other resources, thanks in advance!
Re: Working with large floating point numbers.
Postby Sprite » Wed Mar 15, 2023 12:19 am
That overflow seems to happen at the limit of a 32-bit integer. I'd guess the double variable itself doesn't overflow; it's the println routine that messes up. Perhaps you can see what happens if you replace that with a printf("%f\n", test); ?
Users browsing this forum: Bing [Bot] and 2 guests
