The SerialToSerialBT compiling failed for ESP32S3 why?
lladam
Postby lladam » Wed Mar 15, 2023 10:18 pm
Hi all,
the compiling for ESP32 Dev Module passed, failed for ESP32 S3, why and how to fix?
Adam
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
#if !defined(CONFIG_BT_SPP_ENABLED)
#error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
#endif
BluetoothSerial SerialBT;
  SerialBT.begin("ESP32test"); //Bluetooth device name
  Serial.println("The device started, now you can pair it with bluetooth!");
  if (Serial.available()) {
    SerialBT.write(Serial.read());
  if (SerialBT.available()) {
    Serial.write(SerialBT.read());
  delay(20);
ERROR:
Arduino: 1.8.19 (Windows 10), Board: "ESP32S3 Dev Module, Disabled, Disabled, QIO 80MHz, 4MB (32Mb), Core 1, Core 1, Hardware CDC and JTAG, Enabled, Disabled, Disabled, UART0 / Hardware CDC, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), 921600, None, Disabled"
SerialToSerialBT_m:15:2: error: #error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
MicroController
Re: The SerialToSerialBT compiling failed for ESP32S3 why?
Postby MicroController » Thu Mar 16, 2023 1:48 am
I think the error message could not be any clearer.
The original ESP32 has the required hardware for SPP (Bluetooth "classic", or "BR/EDR"), the ESP32S3 does not (BLE only); so nothing that could be fixed here.
Users browsing this forum: Bytespider, PerplexityBot and 3 guests
