when the server stop the stream transfering?
yangjun1222
Postby yangjun1222 » Thu Mar 23, 2023 3:30 am
HI, I am reading the web cam server example project. I write a simple c program using vs code.
Code: Untitled.c Select all
#include  "camera_index.h"
int main()
FILE *file = fopen("index1.bin", "w");
// Check if the file is opened successfully
if (file == NULL)
printf("Error opening file\\n");
return 1;
// Write each element of the array into the file
for (int i = 0; i < 4408; i++)
fputc(index_ov3660_html_gz[i], file);
// Close the file
fclose(file);
return 0;
then gzip -d index1.bin -c > index1.html, I get the html file (following ignore the css, html part of the file )
Code: Untitled.js Select all
document.addEventListener('DOMContentLoaded', function (event) {
var baseHost = document.location.origin
var streamUrl = baseHost + ':81'
const hide = el => {
el.classList.add('hidden')
const show = el => {
el.classList.remove('hidden')
const disable = el => {
el.classList.add('disabled')
el.disabled = true
const enable = el => {
el.classList.remove('disabled')
el.disabled = false
const updateValue = (el, value, updateRemote) => {
updateRemote = updateRemote == null ? true : updateRemote
let initialValue
if (el.type === 'checkbox') {
initialValue = el.checked
value = !!value
el.checked = value
initialValue = el.value
el.value = value
if (updateRemote && initialValue !== value) {
updateConfig(el);
} else if(!updateRemote){
if(el.id === "aec"){
value ? hide(exposure) : show(exposure)
} else if(el.id === "agc"){
if (value) {
show(gainCeiling)
hide(agcGain)
hide(gainCeiling)
show(agcGain)
} else if(el.id === "awb_gain"){
value ? show(wb) : hide(wb)
} else if(el.id === "face_recognize"){
value ? enable(enrollButton) : disable(enrollButton)
function updateConfig (el) {
let value
switch (el.type) {
case 'checkbox':
value = el.checked ? 1 : 0
break
case 'range':
case 'select-one':
value = el.value
break
case 'button':
case 'submit':
value = '1'
break
default:
return
const query = `${baseHost}/control?var=${el.id}&val=${value}`
fetch(query)
.then(response => {
console.log(`request to ${query} finished, status: ${response.status}`)
document
.querySelectorAll('.close')
.forEach(el => {
el.onclick = () => {
hide(el.parentNode)
// read initial values
fetch(`${baseHost}/status`)
.then(function (response) {
return response.json()
.then(function (state) {
document
.querySelectorAll('.default-action')
.forEach(el => {
updateValue(el, state[el.id], false)
const view = document.getElementById('stream')
const viewContainer = document.getElementById('stream-container')
const stillButton = document.getElementById('get-still')
const streamButton = document.getElementById('toggle-stream')
const enrollButton = document.getElementById('face_enroll')
const closeButton = document.getElementById('close-stream')
const stopStream = () => {
window.stop();
streamButton.innerHTML = 'Start Stream'
const startStream = () => {
view.src = `${streamUrl}/stream`
show(viewContainer)
streamButton.innerHTML = 'Stop Stream'
// Attach actions to buttons
stillButton.onclick = () => {
stopStream()
view.src = `${baseHost}/capture?_cb=${Date.now()}`
show(viewContainer)
closeButton.onclick = () => {
stopStream()
hide(viewContainer)
streamButton.onclick = () => {
const streamEnabled = streamButton.innerHTML === 'Stop Stream'
if (streamEnabled) {
stopStream()
startStream()
enrollButton.onclick = () => {
updateConfig(enrollButton)
// Attach default on change action
document
.forEach(el => {
el.onchange = () => updateConfig(el)
// Custom actions
// Gain
const agc = document.getElementById('agc')
const agcGain = document.getElementById('agc_gain-group')
const gainCeiling = document.getElementById('gainceiling-group')
agc.onchange = () => {
updateConfig(agc)
if (agc.checked) {
show(gainCeiling)
hide(agcGain)
hide(gainCeiling)
show(agcGain)
// Exposure
const aec = document.getElementById('aec')
const exposure = document.getElementById('aec_value-group')
aec.onchange = () => {
updateConfig(aec)
aec.checked ? hide(exposure) : show(exposure)
// AWB
const awb = document.getElementById('awb_gain')
const wb = document.getElementById('wb_mode-group')
awb.onchange = () => {
updateConfig(awb)
awb.checked ? show(wb) : hide(wb)
// Detection and framesize
const detect = document.getElementById('face_detect')
const recognize = document.getElementById('face_recognize')
const framesize = document.getElementById('framesize')
framesize.onchange = () => {
updateConfig(framesize)
if (framesize.value > 5) {
updateValue(detect, false)
updateValue(recognize, false)
detect.onchange = () => {
alert("Please select CIF or lower resolution before enabling this feature!");
return;
updateConfig(detect)
if (!detect.checked) {
recognize.onchange = () => {
return;
updateConfig(recognize)
if (recognize.checked) {
updateValue(detect, true)
then I read the app_httpd.cpp and the index.html I got. I understand how the stream server start, but then it enters a dead loop. the browser stop the stream through : window.stop(), how does the server receive this message?I can not find a break in this dead loop which is caused by a request from browser?
static esp_err_t stream_handler(httpd_req_t *req)
while(true){.......................}
noweare
Re: when the server stop the stream transfering?
Postby noweare » Sat Mar 25, 2023 4:26 pm
Good question.
No doubt that the javascript and the camera application is very advanced and not easily understood.
The furthest I could get was "stop stream" button on the browser is pressed which runs the stopStream function which executes window.stop command. window.stop command discontinues loading the stream-container and hides it from view. This causes
stream handler code on the esp32 to return a "send response error" while trying to send a chunk.
I am trying to learn advanced javascript/html/css using this application so I can use it in my own projects. Learning HTML and CSS
is not that difficult but integrating javascript with esp32 code is more of a challenge.
I know this answer is not complete and could be much better answered by an experienced programmer.
Good luck
Users browsing this forum: Semrush [Bot] and 5 guests
