is the MIFA PCB trace bendable? to 90 degrees (vertically)
wesam.co
Postby wesam.co » Mon Oct 09, 2017 7:41 pm
i'm talking about the ESP32-WROVER-I module,
does it come with the MIFA PCB trace? like this
also how to purchase a compatible U.FL connector?
WiFive
Re: is the MIFA PCB trace bendable? to 90 degrees (vertically)
Postby WiFive » Tue Oct 10, 2017 12:53 am
No it is a rigid pcb. Ipex/u.fl should be standard. The part should be in bom of wrover module ref design.
wesam.co
Postby wesam.co » Tue Oct 10, 2017 2:09 pm
thanks WiFive,
I meant how to purchase a compatible antenna, so all antennas with a Ipex/u.fl connector should work?
is there a module without the pcb antenna and only with the connector?
wesam.co
Postby wesam.co » Sat Oct 21, 2017 5:08 pm
thanks for the reply. :)
do you think I can make it work?
break it or dremel it, and solder it vertically, do you think it will work?
this works out perfectly in my project's design and makes big cost savings,
no need to purchase and assembly an antenna other than making it fit in the design..
Users browsing this forum: meta-externalagent, Semrush [Bot] and 2 guests
