"ModuleNotFoundError: No module named 'chardet'" during build on MacOS M1.
corneo
Postby corneo » Thu Mar 30, 2023 12:52 am
I'm running into a problem using ESP-IDF on M1 mac. I've tried everything I've found to resolve it, but obviously, I have had no luck. The crux is that the "chardet" python module is missing. All the similar problems I have read about involving missing 'chardet' come down to the requirement to install Rosetta. I have done that. The softwareupdate command does report failure, but feedback on that says it's not a problem and to ignore it. (I'm skeptical.)
esolving esp32dev dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
Error: Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards ... 32dev.html
PLATFORM: Espressif 32 (6.1.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-espidf @ 3.50001.0 (5.0.1)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40500.0 (4.5.0)
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 11.2.0+2022r1
Reading CMake configuration...
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
See also "/Users/tim/Library/CloudStorage/Dropbox/tim/Projects/Electronics/PlatformIO/Projects/WiFiManager-sandbox/.pio/build/esp32dev/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
CMake Error at /Users/tim/.platformio/packages/framework-espidf/tools/cmake/build.cmake:519 (message):
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/requests/compat.py", line 11, in <module>
import chardet
During handling of the above exception, another exception occurred:
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/idf_component_manager/prepare_components/__main__.py", line 4, in <module>
from .prepare import main
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/idf_component_manager/prepare_components/prepare.py", line 18, in <module>
from ..core import ComponentManager
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/idf_component_manager/core.py", line 17, in <module>
import requests
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/requests/__init__.py", line 45, in <module>
from .exceptions import RequestsDependencyWarning
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/requests/exceptions.py", line 9, in <module>
from .compat import JSONDecodeError as CompatJSONDecodeError
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/requests/compat.py", line 13, in <module>
import charset_normalizer as chardet
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/__init__.py", line 24, in <module>
from .api import from_bytes, from_fp, from_path
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/api.py", line 5, in <module>
from .cd import (
File "/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/cd.py", line 9, in <module>
from .md import is_suspiciously_successive_range
ImportError:
dlopen(/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/md.cpython-311-darwin.so,
0x0002): tried:
'/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/md.cpython-311-darwin.so'
(mach-o file, but is an incompatible architecture (have 'arm64', need
'x86_64')),
'/System/Volumes/Preboot/Cryptexes/OS/Users/tim/.platformio/penv/.espidf-5.0.1/lib/python3.11/site-packages/charset_normalizer/md.cpython-311-darwin.so'
(no such file),
'x86_64'))
/Users/tim/.platformio/packages/framework-espidf/tools/cmake/project.cmake:440 (idf_build_process)
CMakeLists.txt:3 (project)
========================== [FAILED] Took 1.03 seconds ==========================
How can I work around this? [short of running windows or using a non-M1 mac. (;->)]
corneo
Re: "ModuleNotFoundError: No module named 'chardet'" during build on MacOS M1.
Postby corneo » Fri Mar 31, 2023 12:46 am
Darn... crickets.
larboyer
Postby larboyer » Sun May 14, 2023 9:53 pm
I believe I've finally solved this issue. When you install Espressif on mac m1 machines (and maybe elsewhere) it installs it's own version of Python. For me this was located under the 'hidden' espressif dir
~/.espressif/python_env/idf5.2_py3.9_env/lib/python3.9/site-packages.
However, for some reason, they forgot to install that 'chardet' package.
When I would manually do a 'pip install chardet' it would install properly, but in the _mac_ python installation, which, for me, was located:
~/Library/Python/3.9/lib/python/site-packages
To solve, this, find out where pip puts chardet
pip show chardet
Then go to that directory and then copy it to the espressif directory, something like
cd ~/Library/Python/3.9/lib/python/site-packages
cp -R chardet ~/.espressif/python_env/idf5.2_py3.9_env/lib/python3.9/site-packages
Hope this helps some other dev out there not loose 6 hours like me ;>)
hcamacho
Postby hcamacho » Sat Feb 24, 2024 7:42 pm
Here is a way to solve this problem directly. If you look at the error, just above you will see a path for the venv:
CMake Error at /Users/xxxxxx/esp/esp-idf/tools/cmake/build.cmake:544 (message):
    File "/Users/xxxxx/.espressif/python_env/idf5.2_py3.9_env/lib/python3.9/site-packages/requests/compat.py", line 11, in <module>
      import chardet
Perform the following:
% cd /Users/xxxxxx/.espressif/python_env
% ls
idf5.2_py3.9_env
% cd idf5.2_py3.9_env/bin
% . ./activate
(idf5.2_py3.9_env) % pip install chardet
Collecting chardet
  Downloading chardet-5.2.0-py3-none-any.whl.metadata (3.4 kB)
Downloading chardet-5.2.0-py3-none-any.whl (199 kB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 199.4/199.4 kB 3.8 MB/s eta 0:00:00
Installing collected packages: chardet
Successfully installed chardet-5.2.0
This will install chardet directly to the venv that esp32-idf is using.
HFC
Users browsing this forum: Bing [Bot], ChatGPT-User, meta-externalagent and 12 guests
