Hi all,
I'm having a problem with the ESP-WROOM-32 .
The problem is that when I power the ESP it gives the following message.
<<" ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x21 (DOWNLOAD_BOOT(UART0/UART1/SDIO_FEI_REO_V2))
waiting for download ">>
however Esp is fool functional ,and the circuit to boot works perfectly.
I upload program via Arduino IDE with board->ESP32 Wrover Module.
does anyone know how my ESP after power on stop boot and start its program normally??
(POWERON_RESET) after power on the esp
Re: (POWERON_RESET) after power on the esp
Is there something connected to GPIO0 of the ESP? If this is pulled low, the chip will go into download mode.
WROVER != WROOM.
Switch board definitions.
As for boot-up, it sounds like you are also pressing the IO0 button (boot) instead of just reset/rst. Press only ONE button, unless you are trying to upload (which you shouldn't need to press any buttons for, if your setup is working correctly).
Users browsing this forum: Bing [Bot] and 7 guests
