Action in Github: Using custom partition table alter the build folder access
c.Hicham
Postby c.Hicham » Thu Apr 13, 2023 2:13 pm
I have the following action in my Github repository for esp32 project
on:
  push:
    branches: [master]
jobs:
  build:
    runs-on: ubuntu-latest
    steps:
      - name: Checkout repo
        uses: actions/checkout@v3
        with:
          submodules: 'recursive'
          fetch-depth: 0
      - name: esp-idf build
        uses: espressif/esp-idf-ci-action@v1
        with:
          esp_idf_version: v4.3
          target: esp32
      - name: Get latest tag name
        run: |
          tag=$(git describe --tags --abbrev=0 --match "v*")
          echo "value=${tag:1}" >> $GITHUB_OUTPUT
      - name: folder settings
        run: ls -l /
      - name: build folder settings
        run: ls -l build
      - name: Build and Export Binaries
        env:
          version_value: ${{ steps.version_value.outputs.value }}
        run: |
          sudo chmod a+w build
          mv build/*.bin build/"${version_value}".bin
          cp build/*.bin ${{github.workspace}}/
        working-directory: ${{github.workspace}}
      - name: Upload Artifacts
        uses: actions/upload-artifact@v3
        with:
          path: |
            *.bin
This works well and I can see the artifacts when using the default sdkconfig ( partition table only )
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=y
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
# CONFIG_PARTITION_TABLE_CUSTOM is not set
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_singleapp.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
Changing the above part to
# Partition Table
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
I get the following error
STEP : Build and Export Binaries
Run sudo chmod a+w build
  cp build/*.bin /home/runner/work/esp_idf_build_test/esp_idf_build_test/
  mv /home/runner/work/esp_idf_build_test/esp_idf_build_test/*.bin /home/runner/work/esp_idf_build_test/esp_idf_build_test/"${version_value}".bin
  shell: /usr/bin/bash -e {0}
  env:
    version_value: 0.0.2
mv: target '/home/runner/work/esp_idf_build_test/esp_idf_build_test/0.0.2.bin' is not a directory
Error: Process completed with exit code [1](https://github.com/DDANPEAL/esp_idf_build_test/actions/runs/4678519626/jobs/8287348320#step:7:1).
I'm not sure how further I can investigate this !
I check folders permission for when it fails or success and didn't see any changes
MicroController
Re: Action in Github: Using custom partition table alter the build folder access
Postby MicroController » Thu Apr 13, 2023 9:45 pm
How many *.bin files are there in the build directory?
c.Hicham
Postby c.Hicham » Fri Apr 28, 2023 7:48 am
Exactly, this was my issue.
Thank you for the tip
Users browsing this forum: Amazon [Bot], ChatGPT-User, Google [Bot], PerplexityBot, PetalBot, YisouSpider and 2 guests
