Question about reset RC and boot network
Posted: Sat Apr 22, 2023 2:35 pm
by n47h4n
In Espressif documentations (ESP32-S2, S3, C3) it is adviced to use a RC network made of 10k resistor to VCC and 1uF capacitor to GND.
But in most schematics a 0.1uF capacitor is used.
My question is what value one must use?
Same for "boot" pin. 1k resistor and 10pF capacitor. Is that good?
Thanks for your responses.
Re: Question about reset RC and boot network
Posted: Sun Apr 23, 2023 2:14 am
by Sprite
For the reset, it depends on your power setup (slow rising power needs a larger capacitor) as well as the way you program the board: if you use the two-transistor auto-download mode circuit, some PCs/OSses need a slower reset requiring a larger capacitor. If you use internal USB for programming and have a fast-rising power supply (e.g. USB with a LDO with not too much decoupling capacitance), an 0.1uF + 10K will suffice.
No idea what that 10pF is good for (especially as the switch probably has a parasitic capacitance in the same order of magnitude), where do you see that?
[SOLVED] Question about reset RC and boot network
Posted: Sun Apr 23, 2023 6:09 am
by n47h4n
@ESP_Sprite thanks
About the 10pF capacitor, I saw it on this schematic https://files.seeedstudio.com/wiki/XIAO ... C3-SCH.pdf
I think you are right. It must be there to avoid parasitic bounces on the button.
