The ESP32 send UDP data from a camera module to PC Windows and
it works only when I touch the ESP32 antenna.
Any clue ?. Thanks in advance.
Weird WiFi behaviour
santanapablo1975
Re: Weird WiFi behaviour
Hi
I it just a workaround, go to make menuconfig, and in the PHY section reduce the power to 0 dBm for example, and try again.
Regards
Juan
Regards
Juan
The camera module clock (20 MHz ) produced interference on the antenna.
The problem disappeared when the clock wire was shielded.
