Using tinyusb from a component
ghoti57
Postby ghoti57 » Mon Apr 24, 2023 7:24 am
ESP-IDF 5.0.1
Windows 11
I originally posted this under hardware but in hindsight this is a tool problem so I'm re-posting here (and closing original post)
I can create a fairly trivial project using tinyusb that creates two cdc-acm serial ports and echoes input from each in the other (test.zip).
However if I try to move usb.c and usb.h into a component I can't get the system to build.
In the first instance i just moved usb.c and usb.h to components\usb
created components\usb\CmakeLists.txt
CODE: SELECT ALL
idf_component_register(
SRCS "usb.c"
INCLUDE_DIRS "."
and updated main\CMakeLists.txt
CODE: SELECT ALL
# See the build system documentation in IDF programming guide
# for more information about component CMakeLists.txt files.
test.zip
simple working project
(2.65 KiB) Downloaded 368 times
SRCS main.c
REQUIRES usb
Attempting to build now produces the following errors
CODE: SELECT ALL
<path>/eclipse-workspace/test1/components/usb/usb.c:6:10: fatal error: tinyusb.h: No such file or directory
6 | #include "tinyusb.h"
compilation terminated.
<path>/eclipse-workspace/test1/managed_components/espressif__esp_tinyusb/tinyusb.c:12:10: fatal error: esp_private/usb_phy.h: No such file or directory
12 | #include "esp_private/usb_phy.h"
The first can be fixed by adding a REQUIRES line to components\usb\CMakeLists.txt
CODE: SELECT ALL
SRCS "usb.c"
INCLUDE_DIRS "."
REQUIRES tinyusb
However, I can find no way to eliminate the second error.
I've tried moving idf_components.yml to various other parts of the project to no avail.
test1.zip is my latest component version
Anybody know how to get rid of this error please
test1.zip
last build error with component
(3.24 KiB) Downloaded 366 times
broderio
Re: Using tinyusb from a component
Postby broderio » Tue Jan 16, 2024 6:27 am
I believe this problem is caused by having a custom component of the same name as the ESP IDF usb component. I was able to get this to compile by renaming your "usb" component to "my_usb" while using ESP-IDFv5.1.2: https://github.com/espressif/esp-idf/tree/v5.1.2. I had to change the main directory CMakeLists.txt to REQUIRE "my_usb" rather than "usb":
    SRCS main.c
    REQUIRES my_usb
Here is the rewritten test1 that you provided as it was when I was able to compile it.
test1_fixed.zip
(23.68 KiB) Downloaded 324 times
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot], PetalBot, RathiSonika and 3 guests
