Implicit declaration esp_timer_get_time()
Posted: Tue Apr 25, 2023 10:19 am
by Jorggels
Code: Untitled.c Select all
#include "freertos/task.h"
#include "driver/gpio.h"
#include "esp32/rom/ets_sys.h"
#include "ds18b20.h"
// OneWire commands
#define GETTEMP 0x44 // Tells device to take a temperature reading and put it on the scratchpad
#define SKIPROM 0xCC // Command to address all devices on the bus
#define SELECTDEVICE 0x55 // Command to address all devices on the bus
#define COPYSCRATCH 0x48 // Copy scratchpad to EEPROM
#define READSCRATCH 0xBE // Read from scratchpad
#define WRITESCRATCH 0x4E // Write to scratchpad
#define RECALLSCRATCH 0xB8 // Recall from EEPROM to scratchpad
#define READPOWERSUPPLY 0xB4 // Determine if device needs parasite power
#define ALARMSEARCH 0xEC // Query bus for devices with an alarm condition
// Scratchpad locations
#define TEMP_LSB 0
#define TEMP_MSB 1
#define HIGH_ALARM_TEMP 2
#define LOW_ALARM_TEMP 3
#define CONFIGURATION 4
#define INTERNAL_BYTE 5
#define COUNT_REMAIN 6
#define COUNT_PER_C 7
#define SCRATCHPAD_CRC 8
// DSROM FIELDS
#define DSROM_FAMILY 0
#define DSROM_CRC 7
// Device resolution
#define TEMP_9_BIT 0x1F // 9 bit
#define TEMP_10_BIT 0x3F // 10 bit
#define TEMP_11_BIT 0x5F // 11 bit
#define TEMP_12_BIT 0x7F // 12 bit
uint8_t DS_GPIO;
uint8_t init=0;
uint8_t bitResolution=12;
uint8_t devices=0;
DeviceAddress ROM_NO;
uint8_t LastDiscrepancy;
uint8_t LastFamilyDiscrepancy;
bool LastDeviceFlag;
/// Sends one bit to bus
void ds18b20_write(char bit){
if (bit & 1) {
gpio_set_direction(DS_GPIO, GPIO_MODE_OUTPUT);
noInterrupts();
gpio_set_level(DS_GPIO,0);
ets_delay_us(6);
gpio_set_direction(DS_GPIO, GPIO_MODE_INPUT); // release bus
ets_delay_us(64);
interrupts();
} else {
noInterrupts();
ets_delay_us(60);
ets_delay_us(10);
interrupts();
// Reads one bit from bus
unsigned char ds18b20_read(void){
unsigned char value = 0;
noInterrupts();
gpio_set_level(DS_GPIO, 0);
ets_delay_us(6);
ets_delay_us(9);
value = gpio_get_level(DS_GPIO);
ets_delay_us(55);
interrupts();
return (value);
// Sends one byte to bus
void ds18b20_write_byte(char data){
unsigned char i;
unsigned char x;
for(i=0;i<8;i++){
x = data>>i;
x &= 0x01;
ds18b20_write(x);
ets_delay_us(100);
// Reads one byte from bus
unsigned char ds18b20_read_byte(void){
unsigned char i;
unsigned char data = 0;
for (i=0;i<8;i++)
if(ds18b20_read()) data|=0x01<<i;
ets_delay_us(15);
return(data);
// Sends reset pulse
unsigned char ds18b20_reset(void){
unsigned char presence;
noInterrupts();
ets_delay_us(480);
gpio_set_level(DS_GPIO, 1);
ets_delay_us(70);
presence = (gpio_get_level(DS_GPIO) == 0);
ets_delay_us(410);
interrupts();
return presence;
bool ds18b20_setResolution(const DeviceAddress tempSensorAddresses[], int numAddresses, uint8_t newResolution) {
bool success = false;
// handle the sensors with configuration register
newResolution = constrain(newResolution, 9, 12);
uint8_t newValue = 0;
ScratchPad scratchPad;
// loop through each address
for (int i = 0; i < numAddresses; i++){
// we can only update the sensor if it is connected
if (ds18b20_isConnected((DeviceAddress*) tempSensorAddresses[i], scratchPad)) {
switch (newResolution) {
case 12:
newValue = TEMP_12_BIT;
break;
case 11:
newValue = TEMP_11_BIT;
break;
case 10:
newValue = TEMP_10_BIT;
break;
case 9:
default:
newValue = TEMP_9_BIT;
break;
// if it needs to be updated we write the new value
if (scratchPad[CONFIGURATION] != newValue) {
scratchPad[CONFIGURATION] = newValue;
ds18b20_writeScratchPad((DeviceAddress*) tempSensorAddresses[i], scratchPad);
// done
success = true;
return success;
void ds18b20_writeScratchPad(const DeviceAddress *deviceAddress, const uint8_t *scratchPad) {
ds18b20_reset();
ds18b20_select(deviceAddress);
ds18b20_write_byte(WRITESCRATCH);
ds18b20_write_byte(scratchPad[HIGH_ALARM_TEMP]); // high alarm temp
ds18b20_write_byte(scratchPad[LOW_ALARM_TEMP]); // low alarm temp
ds18b20_write_byte(scratchPad[CONFIGURATION]);
ds18b20_reset();
bool ds18b20_readScratchPad(const DeviceAddress *deviceAddress, uint8_t* scratchPad) {
// send the reset command and fail fast
int b = ds18b20_reset();
if (b == 0) return false;
ds18b20_write_byte(READSCRATCH);
// Read all registers in a simple loop
// byte 0: temperature LSB
// byte 1: temperature MSB
// byte 2: high alarm temp
// byte 3: low alarm temp
// byte 4: DS18B20 & DS1822: configuration register
// byte 5: internal use & crc
// byte 6: DS18B20 & DS1822: store for crc
// byte 7: DS18B20 & DS1822: store for crc
// byte 8: SCRATCHPAD_CRC
for (uint8_t i = 0; i < 9; i++) {
scratchPad[i] = ds18b20_read_byte();
return (b == 1);
void ds18b20_select(const DeviceAddress *address){
uint8_t i;
ds18b20_write_byte(SELECTDEVICE); // Choose ROM
for (i = 0; i < 8; i++) ds18b20_write_byte(((uint8_t *)address)[i]);
void ds18b20_requestTemperatures(){
ds18b20_reset();
ds18b20_write_byte(SKIPROM);
ds18b20_write_byte(GETTEMP);
unsigned long start = esp_timer_get_time() / 1000ULL;
while (!isConversionComplete() && ((esp_timer_get_time() / 1000ULL) - start < millisToWaitForConversion())) vPortYield();
bool isConversionComplete() {
uint8_t b = ds18b20_read();
return (b == 1);
uint16_t millisToWaitForConversion() {
switch (bitResolution) {
case 9:
return 94;
case 10:
return 188;
case 11:
return 375;
default:
return 750;
bool ds18b20_isConnected(const DeviceAddress *deviceAddress, uint8_t *scratchPad) {
bool b = ds18b20_readScratchPad(deviceAddress, scratchPad);
return b && !ds18b20_isAllZeros(scratchPad) && (ds18b20_crc8(scratchPad, 8) == scratchPad[SCRATCHPAD_CRC]);
uint8_t ds18b20_crc8(const uint8_t *addr, uint8_t len){
uint8_t crc = 0;
while (len--) {
crc = *addr++ ^ crc; // just re-using crc as intermediate
crc = pgm_read_byte(dscrc2x16_table + (crc & 0x0f)) ^
pgm_read_byte(dscrc2x16_table + 16 + ((crc >> 4) & 0x0f));
return crc;
bool ds18b20_isAllZeros(const uint8_t * const scratchPad) {
for (size_t i = 0; i < 9; i++) {
if (scratchPad[i] != 0) {
return false;
return true;
float ds18b20_getTempF(const DeviceAddress *deviceAddress) {
if (ds18b20_isConnected(deviceAddress, scratchPad)){
int16_t rawTemp = calculateTemperature(deviceAddress, scratchPad);
if (rawTemp <= DEVICE_DISCONNECTED_RAW)
return DEVICE_DISCONNECTED_F;
// C = RAW/128
// F = (C*1.8)+32 = (RAW/128*1.8)+32 = (RAW*0.0140625)+32
return ((float) rawTemp * 0.0140625f) + 32.0f;
float ds18b20_getTempC(const DeviceAddress *deviceAddress) {
// C = RAW/128
return (float) rawTemp/128.0f;
// reads scratchpad and returns fixed-point temperature, scaling factor 2^-7
int16_t calculateTemperature(const DeviceAddress *deviceAddress, uint8_t* scratchPad) {
int16_t fpTemperature = (((int16_t) scratchPad[TEMP_MSB]) << 11) | (((int16_t) scratchPad[TEMP_LSB]) << 3);
return fpTemperature;
// Returns temperature from sensor
float ds18b20_get_temp(void) {
if(init==1){
unsigned char check;
char temp1=0, temp2=0;
check=ds18b20_RST_PULSE();
if(check==1)
ds18b20_send_byte(0xCC);
ds18b20_send_byte(0x44);
vTaskDelay(750 / portTICK_PERIOD_MS);
ds18b20_send_byte(0xBE);
temp1=ds18b20_read_byte();
temp2=ds18b20_read_byte();
float temp=0;
temp=(float)(temp1+(temp2*256))/16;
return temp;
else{return 0;}
else{return 0;}
void ds18b20_init(int GPIO) {
DS_GPIO = GPIO;
gpio_pad_select_gpio(DS_GPIO);
init = 1;
// You need to use this function to start a search again from the beginning.
// You do not need to do it for the first search, though you could.
void reset_search() {
devices=0;
// reset the search state
LastDiscrepancy = 0;
LastDeviceFlag = false;
LastFamilyDiscrepancy = 0;
for (int i = 7; i >= 0; i--) {
ROM_NO[i] = 0;
// --- Replaced by the one from the Dallas Semiconductor web site ---
// Perform the 1-Wire Search Algorithm on the 1-Wire bus using the existing
// search state.
// Return TRUE : device found, ROM number in ROM_NO buffer
// FALSE : device not found, end of search
bool search(uint8_t *newAddr, bool search_mode) {
uint8_t id_bit_number;
uint8_t last_zero, rom_byte_number;
bool search_result;
uint8_t id_bit, cmp_id_bit;
unsigned char rom_byte_mask, search_direction;
// initialize for search
id_bit_number = 1;
last_zero = 0;
rom_byte_number = 0;
rom_byte_mask = 1;
search_result = false;
// if the last call was not the last one
if (!LastDeviceFlag) {
// 1-Wire reset
if (!ds18b20_reset()) {
// reset the search
return false;
// issue the search command
if (search_mode == true) {
ds18b20_write_byte(0xF0); // NORMAL SEARCH
} else {
ds18b20_write_byte(0xEC); // CONDITIONAL SEARCH
// loop to do the search
do {
// read a bit and its complement
id_bit = ds18b20_read();
cmp_id_bit = ds18b20_read();
// check for no devices on 1-wire
if ((id_bit == 1) && (cmp_id_bit == 1)) {
break;
} else {
// all devices coupled have 0 or 1
if (id_bit != cmp_id_bit) {
search_direction = id_bit; // bit write value for search
} else {
// if this discrepancy if before the Last Discrepancy
// on a previous next then pick the same as last time
if (id_bit_number < LastDiscrepancy) {
search_direction = ((ROM_NO[rom_byte_number]
& rom_byte_mask) > 0);
} else {
// if equal to last pick 1, if not then pick 0
search_direction = (id_bit_number == LastDiscrepancy);
// if 0 was picked then record its position in LastZero
if (search_direction == 0) {
last_zero = id_bit_number;
// check for Last discrepancy in family
if (last_zero < 9)
LastFamilyDiscrepancy = last_zero;
// set or clear the bit in the ROM byte rom_byte_number
// with mask rom_byte_mask
if (search_direction == 1)
ROM_NO[rom_byte_number] |= rom_byte_mask;
else
ROM_NO[rom_byte_number] &= ~rom_byte_mask;
// serial number search direction write bit
ds18b20_write(search_direction);
// increment the byte counter id_bit_number
// and shift the mask rom_byte_mask
id_bit_number++;
rom_byte_mask <<= 1;
// if the mask is 0 then go to new SerialNum byte rom_byte_number and reset mask
if (rom_byte_mask == 0) {
rom_byte_number++;
rom_byte_mask = 1;
} while (rom_byte_number < 8); // loop until through all ROM bytes 0-7
// if the search was successful then
if (!(id_bit_number < 65)) {
// search successful so set LastDiscrepancy,LastDeviceFlag,search_result
LastDiscrepancy = last_zero;
// check for last device
if (LastDiscrepancy == 0) {
LastDeviceFlag = true;
search_result = true;
// if no device found then reset counters so next 'search' will be like a first
if (!search_result || !ROM_NO[0]) {
devices=0;
} else {
for (int i = 0; i < 8; i++){
newAddr[i] = ROM_NO[i];
devices++;
return search_result;
Re: Implicit declaration esp_timer_get_time()
Posted: Mon May 08, 2023 9:14 pm
by MicroController
I suggest including the esp_timer header file from the respective component.
