IDF 5.0.1 on ESP32-S3 with CONFIG_ESP_TLS_USE_SECURE_ELEMENT
Posted: Fri May 05, 2023 4:28 am
We are developing a product based on ESP32-S3 and IDF 5.0.1 (current stable). There is also a Microchip ATECC680A-TNGTLS on board, though we will be using ATECC608B-TNGTLS in production.
I have the board up and running, and I am able to access the secure element using ESP-CRYPTOAUTHLIB 3.5.1 as a managed component, with functions such as device identification and reading of the device unique id and public key, so the interface is fully functional.
When I go to establish an MQTTS session esp_mqtt_set_ssl_transport_properties() reports the error:
Clearly the problem is that the Kconfig is preventing the option appearing simply because I am using ESP32-S3, not ESP32.
I edited the Kconfig to:
and the error went away (to be replaced with another, but that's one for me to sort out).
A related issue is that when the session is shut down the I2C driver is apparently unloaded, because subsequent accesses to our RTC on the same I2C bus report the error:
So, what I am asking for is:
Neil
Now, this turns out to be due to a missing configuration option in sdkconfig, specifically: CONFIG_ESP_TLS_USE_SECURE_ELEMENT. I tried to set that option via menuconfig but it simply wasn't there. When I checked the Kconfig for ESP-TLS I found:E (13583) mqtt_client: Secure element not enabled for esp-tls in menuconfig
config ESP_TLS_USE_SECURE_ELEMENT
bool "Use Secure Element (ATECC608A) with ESP-TLS"
depends on [b]IDF_TARGET_ESP32[/b] && ESP_TLS_USING_MBEDTLSI edited the Kconfig to:
depends on ESP_TLS_USING_MBEDTLSA related issue is that when the session is shut down the I2C driver is apparently unloaded, because subsequent accesses to our RTC on the same I2C bus report the error:
I know we are not the only ones to place an RTC on the same bus as the secure element.E (14338) i2c: i2c_master_cmd_begin(1481): i2c driver not installed
- Would it be possible to modify the ESP-TLS Kconfig to not require only ESP32?
- Can ESP-CRYPTOAUTHLIB be modified to install without error if the I2C driver is already loaded at initialisation time, and to leave the driver in place on exit in such a case?
- While I am on the subject, esp_cryptoauthlib_utility has the same ESP32 only problem, so a --chip option would be good
Neil
