GURU meditation error panic at core Zero after BLE host task start
Posted: Sat May 06, 2023 8:41 am
by madhusudan_jadhav
I am using BLPPRPH example. I have modified the example as i wanted to send and recieve the data. Compilation goes ok. but when esp32 starts
Code: Untitled.txt Select all
I (631) cpu_start: Starting scheduler on PRO CPU.
state=1I (2655) BTDM_INIT: BT controller compile version [60aae55]
I (2655) system_api: Base MAC address is not set
I (2655) system_api: read default base MAC address from EFUSE
I (2665) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
thisonethistwothisthreethisdfourthidfivethissixI (3005) NimBLE_BLE_PRPH: BLE Host Task Started
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x400d818c PS : 0x00060d30 A0 : 0x800d78ec A1 : 0x3ffbbc10
0x400d818c: RelayDataMessageHandle at C:/Espressif/tools/espressif-ide/2.9.0/workspace/bleprph/main/gpio.c:162
A2 : 0x00000094 A3 : 0x3ffb7ad4 A4 : 0x3ffc3664 A5 : 0x00000040
A6 : 0x400d5550 A7 : 0x0000cdcd A8 : 0x00000000 A9 : 0x3ffbbbe0
0x400d5550: timer_task at C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_timer/src/esp_timer.c:428
A10 : 0x00000000 A11 : 0x3ffb7ad4 A12 : 0x3ffc1fc2 A13 : 0x00060823
A14 : 0x3ffbbbf0 A15 : 0x0000cdcd SAR : 0x00000012 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000094 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
Backtrace: 0x400d8189:0x3ffbbc10 0x400d78e9:0x3ffbbc30 0x4017b9b7:0x3ffbbc50 0x400952e5:0x3ffbbc80
Re: GURU meditation error panic at core Zero after BLE host task start
Posted: Sat May 06, 2023 8:42 am
which code i should check for unrecognised variable?
Posted: Sat May 06, 2023 9:51 am
i saw it in build file. symbol _n couldnot resolved.
Posted: Sat May 06, 2023 11:30 am
by MicroController
You would certainly get more and better help if you could start to show code that is in any way relevant to your problem.
Posted: Sat May 06, 2023 11:38 am
static int
gatt_svr_chr_access_sec_test(uint16_t conn_handle, uint16_t attr_handle,
struct ble_gatt_access_ctxt *ctxt,
void *arg)
const ble_uuid_t *uuid;
int rc=0;
// uint8_t dats[50]={0};
uuid = ctxt->chr->uuid;
assert (0);
if (ble_uuid_cmp(uuid, &gatt_svr_chr_sec_test_static_uuid.u) == 0) {
switch (ctxt->op) {
case BLE_GATT_ACCESS_OP_READ_CHR:
if(state == 0){
rc = os_mbuf_append(ctxt->om, &send_data,
sizeof (send_data));
return rc == 0 ? 0 : BLE_ATT_ERR_INSUFFICIENT_RES;}
else{
rc = os_mbuf_append(ctxt->om, &send_data1,
sizeof (send_data1));
case BLE_GATT_ACCESS_OP_WRITE_CHR:
printf("Data from the client: %.*s\n", ctxt->om->om_len, ctxt->om->om_data);
// gatt_svr_chr_write(ctxt->om, 1, ctxt->om->om_len,
// &recieve_data, ctxt->om->om_len);
for (int i =0;i < ctxt->om->om_len;i++ ){
recieve_data[i]=ctxt->om->om_data[i];
printf("recievedata =%c\n",recieve_data[i]);
printf("writing done");return 0;
default:
assert(0);
printf("writing error");
return BLE_ATT_ERR_UNLIKELY;
/* Unknown characteristic; the nimble stack should not have called this
* function.
assert(0);
static const struct ble_gatt_svc_def gatt_svr_svcs[] = {
/*** Service: Security test. */
.type = BLE_GATT_SVC_TYPE_PRIMARY,
.uuid = &gatt_svr_svc_sec_test_uuid.u,
.characteristics = (struct ble_gatt_chr_def[])
/*** Characteristic: Static value. */
.uuid = &gatt_svr_chr_sec_test_static_uuid.u,
.access_cb = gatt_svr_chr_access_sec_test,
.flags = BLE_GATT_CHR_F_READ | BLE_GATT_CHR_F_READ_ENC |
BLE_GATT_CHR_F_WRITE | BLE_GATT_CHR_F_WRITE_ENC,
0, /* No more characteristics in this service. */
0, /* No more services. */
void
gatt_svr_register_cb(struct ble_gatt_register_ctxt *ctxt, void *arg)
char buf[BLE_UUID_STR_LEN];
switch (ctxt->op) {
case BLE_GATT_REGISTER_OP_SVC:
MODLOG_DFLT(DEBUG, "registered service %s with handle=%d\n",
ble_uuid_to_str(ctxt->svc.svc_def->uuid, buf),
ctxt->svc.handle);
break;
case BLE_GATT_REGISTER_OP_CHR:
MODLOG_DFLT(DEBUG, "registering characteristic %s with "
"def_handle=%d val_handle=%d\n",
ble_uuid_to_str(ctxt->chr.chr_def->uuid, buf),
ctxt->chr.def_handle,
ctxt->chr.val_handle);
break;
case BLE_GATT_REGISTER_OP_DSC:
MODLOG_DFLT(DEBUG, "registering descriptor %s with handle=%d\n",
ble_uuid_to_str(ctxt->dsc.dsc_def->uuid, buf),
ctxt->dsc.handle);
break;
default:
assert(0);
break;
int
gatt_svr_init(void)
int rc;
ble_svc_gap_init();
ble_svc_gatt_init();
ble_svc_ans_init();
rc = ble_gatts_count_cfg(gatt_svr_svcs);
if (rc != 0) {
return rc;
rc = ble_gatts_add_svcs(gatt_svr_svcs);
if (rc != 0) {
return rc;
return 0;
[Codebox=text file=Untitled.txtstatic void
bleprph_advertise(void)
struct ble_gap_adv_params adv_params;
struct ble_hs_adv_fields fields;
const char *name;
int rc;
* Set the advertisement data included in our advertisements:
* o Flags (indicates advertisement type and other general info).
* o Advertising tx power.
* o Device name.
* o 16-bit service UUIDs (alert notifications).
memset(&fields, 0, sizeof fields);
/* Advertise two flags:
* o Discoverability in forthcoming advertisement (general)
* o BLE-only (BR/EDR unsupported).
fields.flags = BLE_HS_ADV_F_DISC_GEN |
BLE_HS_ADV_F_BREDR_UNSUP;
/* Indicate that the TX power level field should be included; have the
* stack fill this value automatically. This is done by assigning the
* special value BLE_HS_ADV_TX_PWR_LVL_AUTO.
fields.tx_pwr_lvl_is_present = 1;
fields.tx_pwr_lvl = BLE_HS_ADV_TX_PWR_LVL_AUTO;
name = ble_svc_gap_device_name();
fields.name = (uint8_t *)name;
fields.name_len = strlen(name);
fields.name_is_complete = 1;
fields.uuids16 = (ble_uuid16_t[]) {
BLE_UUID16_INIT(GATT_SVR_SVC_ALERT_UUID)
fields.num_uuids16 = 1;
fields.uuids16_is_complete = 1;
rc = ble_gap_adv_set_fields(&fields);
if (rc != 0) {
MODLOG_DFLT(ERROR, "error setting advertisement data; rc=%d\n", rc);
return;
/* Begin advertising. */
memset(&adv_params, 0, sizeof adv_params);
adv_params.conn_mode = BLE_GAP_CONN_MODE_UND;
adv_params.disc_mode = BLE_GAP_DISC_MODE_GEN;
rc = ble_gap_adv_start(own_addr_type, NULL, BLE_HS_FOREVER,
&adv_params, bleprph_gap_event, NULL);
if (rc != 0) {
MODLOG_DFLT(ERROR, "error enabling advertisement; rc=%d\n", rc);
return;
#endif
#if MYNEWT_VAL(BLE_POWER_CONTROL)
static void bleprph_power_control(uint16_t conn_handle)
int rc;
rc = ble_gap_read_remote_transmit_power_level(conn_handle, 0x01 ); // Attempting on LE 1M phy
assert (rc == 0);
rc = ble_gap_set_transmit_power_reporting_enable(conn_handle, 0x1, 0x1);
assert (rc == 0);
#endif
* The nimble host executes this callback when a GAP event occurs. The
* application associates a GAP event callback with each connection that forms.
* bleprph uses the same callback for all connections.
* @param event The type of event being signalled.
* @param ctxt Various information pertaining to the event.
* @param arg Application-specified argument; unused by
* bleprph.
* @return 0 if the application successfully handled the
* event; nonzero on failure. The semantics
* of the return code is specific to the
* particular GAP event being signalled.
static int
bleprph_gap_event(struct ble_gap_event *event, void *arg)
struct ble_gap_conn_desc desc;
int rc;
switch (event->type) {
case BLE_GAP_EVENT_CONNECT:
/* A new connection was established or a connection attempt failed. */
MODLOG_DFLT(INFO, "connection %s; status=%d ",
event->connect.status == 0 ? "established" : "failed",
event->connect.status);
if (event->connect.status == 0) {
rc = ble_gap_conn_find(event->connect.conn_handle, &desc);
assert(rc == 0);
bleprph_print_conn_desc(&desc);
//rc = ble_gap_security_initiate(&desc);
MODLOG_DFLT(INFO, "\n");
if (event->connect.status != 0) {
/* Connection failed; resume advertising. */
#if CONFIG_EXAMPLE_EXTENDED_ADV
ext_bleprph_advertise();
#else
#endif
bleprph_power_control(event->connect.conn_handle);
ble_gap_event_listener_register(&power_control_event_listener,
#endif
return 0;
case BLE_GAP_EVENT_DISCONNECT:
MODLOG_DFLT(INFO, "disconnect; reason=%d ", event->disconnect.reason);
bleprph_print_conn_desc(&event->disconnect.conn);
/* Connection terminated; resume advertising. */
#else
#endif
return 0;
case BLE_GAP_EVENT_CONN_UPDATE:
/* The central has updated the connection parameters. */
MODLOG_DFLT(INFO, "connection updated; status=%d ",
event->conn_update.status);
rc = ble_gap_conn_find(event->conn_update.conn_handle, &desc);
assert(rc == 0);
return 0;
case BLE_GAP_EVENT_ADV_COMPLETE:
MODLOG_DFLT(INFO, "advertise complete; reason=%d",
event->adv_complete.reason);
#if !CONFIG_EXAMPLE_EXTENDED_ADV
#endif
return 0;
case BLE_GAP_EVENT_ENC_CHANGE:
/* Encryption has been enabled or disabled for this connection. */
MODLOG_DFLT(INFO, "encryption change event; status=%d ",
event->enc_change.status);
rc = ble_gap_conn_find(event->enc_change.conn_handle, &desc);
assert(rc == 0);
return 0;
case BLE_GAP_EVENT_SUBSCRIBE:
MODLOG_DFLT(INFO, "subscribe event; conn_handle=%d attr_handle=%d "
"reason=%d prevn=%d curn=%d previ=%d curi=%d\n",
event->subscribe.conn_handle,
event->subscribe.attr_handle,
event->subscribe.reason,
event->subscribe.prev_notify,
event->subscribe.cur_notify,
event->subscribe.prev_indicate,
event->subscribe.cur_indicate);
return 0;
case BLE_GAP_EVENT_MTU:
MODLOG_DFLT(INFO, "mtu update event; conn_handle=%d cid=%d mtu=%d\n",
event->mtu.conn_handle,
event->mtu.channel_id,
event->mtu.value);
return 0;
case BLE_GAP_EVENT_REPEAT_PAIRING:
/* We already have a bond with the peer, but it is attempting to
* establish a new secure link. This app sacrifices security for
* convenience: just throw away the old bond and accept the new link.
/* Delete the old bond. */
rc = ble_gap_conn_find(event->repeat_pairing.conn_handle, &desc);
assert(rc == 0);
ble_store_util_delete_peer(&desc.peer_id_addr);
/* Return BLE_GAP_REPEAT_PAIRING_RETRY to indicate that the host should
* continue with the pairing operation.
return BLE_GAP_REPEAT_PAIRING_RETRY;
case BLE_GAP_EVENT_PASSKEY_ACTION:
ESP_LOGI(tag, "PASSKEY_ACTION_EVENT started \n");
struct ble_sm_io pkey = {0};
int key = 0;
if (event->passkey.params.action == BLE_SM_IOACT_DISP) {
pkey.action = event->passkey.params.action;
pkey.passkey = 123456; // This is the passkey to be entered on peer
ESP_LOGI(tag, "Enter passkey %" PRIu32 "on the peer side", pkey.passkey);
rc = ble_sm_inject_io(event->passkey.conn_handle, &pkey);
ESP_LOGI(tag, "ble_sm_inject_io result: %d\n", rc);
} else if (event->passkey.params.action == BLE_SM_IOACT_NUMCMP) {
ESP_LOGI(tag, "Passkey on device's display: %" PRIu32 , event->passkey.params.numcmp);
ESP_LOGI(tag, "Accept or reject the passkey through console in this format -> key Y or key N");
// if (scli_receive_key(&key)) {
pkey.numcmp_accept = key;
// } else {
pkey.numcmp_accept = 0;
ESP_LOGE(tag, "Timeout! Rejecting the key");
} else if (event->passkey.params.action == BLE_SM_IOACT_OOB) {
static uint8_t tem_oob[16] = {0};
for (int i = 0; i < 16; i++) {
pkey.oob = tem_oob;
} else if (event->passkey.params.action == BLE_SM_IOACT_INPUT) {
ESP_LOGI(tag, "Enter the passkey through console in this format-> key 123456");
/* if (scli_receive_key(&key)) {
pkey.passkey = key;
} else {
pkey.passkey = 0;
ESP_LOGE(tag, "Timeout! Passing 0 as the key");
return 0;
case BLE_GAP_EVENT_TRANSMIT_POWER:
MODLOG_DFLT(INFO, "Transmit power event : status=%d conn_handle=%d reason=%d "
"phy=%d power_level=%x power_level_flag=%d delta=%d",
event->transmit_power.status,
event->transmit_power.conn_handle,
event->transmit_power.reason,
event->transmit_power.phy,
event->transmit_power.transmit_power_level,
event->transmit_power.transmit_power_level_flag,
event->transmit_power.delta);
return 0;
case BLE_GAP_EVENT_PATHLOSS_THRESHOLD:
MODLOG_DFLT(INFO, "Pathloss threshold event : conn_handle=%d current path loss=%d "
"zone_entered =%d",
event->pathloss_threshold.conn_handle,
event->pathloss_threshold.current_path_loss,
event->pathloss_threshold.zone_entered);
return 0;
#endif
return 0;
static void
bleprph_on_reset(int reason)
MODLOG_DFLT(ERROR, "Resetting state; reason=%d\n", reason);
#if CONFIG_EXAMPLE_RANDOM_ADDR
static void
ble_app_set_addr(void)
ble_addr_t addr;
int rc;
/* generate new non-resolvable private address */
rc = ble_hs_id_gen_rnd(0, &addr);
assert(rc == 0);
/* set generated address */
rc = ble_hs_id_set_rnd(addr.val);
assert(rc == 0);
#endif
static void
bleprph_on_sync(void)
int rc;
/* Generate a non-resolvable private address. */
ble_app_set_addr();
#endif
/* Make sure we have proper identity address set (public preferred) */
rc = ble_hs_util_ensure_addr(1);
#else
rc = ble_hs_util_ensure_addr(0);
#endif
assert(rc == 0);
/* Figure out address to use while advertising (no privacy for now) */
rc = ble_hs_id_infer_auto(0, &own_addr_type);
if (rc != 0) {
MODLOG_DFLT(ERROR, "error determining address type; rc=%d\n", rc);
return;
/* Printing ADDR */
uint8_t addr_val[6] = {0};
rc = ble_hs_id_copy_addr(own_addr_type, addr_val, NULL);
MODLOG_DFLT(INFO, "Device Address: ");
#else
#endif
void bleprph_host_task(void *param)
ESP_LOGI(tag, "BLE Host Task Started");
printf("xtaskcreated for nmfghfhfible");
/* This function will return only when nimble_port_stop() is executed */
printf("xtaskcreated for nmible");
nimble_port_run();
printf("ythisisseven");
nimble_port_freertos_deinit();
printf("thisisieight");
void ble_deinit(){
nimble_port_deinit();
void ble_init(void){
int rc;
nimble_port_init();
printf("thisone");
/* Initialize the NimBLE host configuration. */
ble_hs_cfg.reset_cb = bleprph_on_reset;
ble_hs_cfg.sync_cb = bleprph_on_sync;
ble_hs_cfg.gatts_register_cb = gatt_svr_register_cb;
ble_hs_cfg.store_status_cb = ble_store_util_status_rr;
printf("thistwo");
ble_hs_cfg.sm_io_cap = CONFIG_EXAMPLE_IO_TYPE;
#ifdef CONFIG_EXAMPLE_BONDING
ble_hs_cfg.sm_bonding = 1;
#endif
#ifdef CONFIG_EXAMPLE_MITM
ble_hs_cfg.sm_mitm = 1;
#endif
#ifdef CONFIG_EXAMPLE_USE_SC
ble_hs_cfg.sm_sc = 1;
#else
ble_hs_cfg.sm_sc = 0;
#endif
ble_hs_cfg.sm_our_key_dist = 1;
ble_hs_cfg.sm_their_key_dist = 1;
#endif
printf("thisthree");
rc = gatt_svr_init();
assert(rc == 0);
/* Set the default device name. */
printf("thisdfour");
rc = ble_svc_gap_device_name_set("MiBaio");
assert(rc == 0);
printf("thidfive");
/* XXX Need to have template for store */
ble_store_config_init();
printf("thissix");
nimble_port_freertos_init(bleprph_host_task);
printf("thisseven");
///xTaskCreate(&task, "task", 4096, NULL, 5, NULL);
][/Codebox]
int
app_main(void)
/* Initialize NVS — it is used to store PHY calibration data */
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
tm1637_led_t * lcd = tm1637_init(TM1637_CLOCK_PIN, TM1637_DATA_PIN);
tm1637_set_brightness(lcd,4);
//xTaskCreate(&lcd_tm1637_task, "lcd_tm1637_task", 4096, NULL, 4, NULL);
ESP_ERROR_CHECK(ret);
ret = nvs_open("storage", NVS_READWRITE, &mibaio_nvs_handle2);
ret=nvs_get_str(mibaio_nvs_handle2,"myssid",&userid,33);
ret=nvs_get_str(mibaio_nvs_handle2,"mypassword",&password,64);
if(ret == ESP_ERR_NVS_NOT_FOUND) {
send_dat[0]='n';
nvs_close(mibaio_nvs_handle2);
nvs_commit(mibaio_nvs_handle2);
state=1;
printf("state=1");
// app_wifi();
// esp_wifi_scan_stop();
// esp_wifi_stop();
// esp_wifi_deinit();
// vTaskDelay(100/portTICK_PERIOD_MS);
vTaskDelay(1000/portTICK_PERIOD_MS);
ble_init();
RelayDataMessageHandle(&recieve_data[0]);
if(ret==ESP_OK){
state=0;
printf("state=0");
ble_deinit();
esp_wifi_deinit();
ble_init();
Posted: Sat May 06, 2023 2:56 pm
is this the problem?
Posted: Sat May 06, 2023 10:05 pm
by MicroController
static int
Ok, I guess I asked for it... :lol:
And somehow you still managed to not include the RelayDataMessageHandle function where the error occurred...
Posted: Sun May 07, 2023 1:37 am
I did some workaround. now problem is solved
