in my example i am doing wifi scan. after i get the result. i want to start wifi enterprise or bluetooth but during deinit the above error is coming.Codebox=text file=Untitled.txt]void task(void *pvParameter) {
while(1){
vTaskDelay(4000/portTICK_PERIOD_MS);
ESP_ERROR_CHECK(esp_wifi_disconnect() );
vTaskDelay(1000/portTICK_PERIOD_MS);
ESP_LOGI(TAG, "wifi_init_sta stop sta");
ESP_ERROR_CHECK(esp_wifi_stop() );
ESP_LOGI(TAG, "wifi_init_sta deinit sta");
ESP_ERROR_CHECK(esp_wifi_deinit() );
if(k==0){
app();k=1;}
ble_init();
vTaskDelay(pdMS_TO_TICKS(1000));
}[/Codebox]
Code: Untitled.txt Select all
static void wifi_scan(void)
int j =0;
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
assert(sta_netif);
uint16_t number = DEFAULT_SCAN_LIST_SIZE;
wifi_ap_record_t ap_info[DEFAULT_SCAN_LIST_SIZE];
uint16_t ap_count = 0;
memset(ap_info, 0, sizeof(ap_info));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_start());
esp_wifi_scan_start(NULL, true);
ESP_ERROR_CHECK(esp_wifi_scan_get_ap_records(&number, ap_info));
ESP_ERROR_CHECK(esp_wifi_scan_get_ap_num(&ap_count));
ESP_LOGI(TAG, "Total APs scanned = %u", ap_count);
j=0;
for (int i = 0; (i < DEFAULT_SCAN_LIST_SIZE) && (i < ap_count); i++) {
send_dat[0]='S';
send_data1[j]='^';
j++;
ESP_LOGI(TAG, "SSID \t\t%s", ap_info[i].ssid);
for (int k=0;k<33;k++){
send_data1[j] =ap_info[i].ssid[k];
printf("%c",send_data1[k]);
j++;
ESP_LOGI(TAG, "RSSI \t\t%d", ap_info[i].rssi);
print_auth_mode(ap_info[i].authmode);
if (ap_info[i].authmode != WIFI_AUTH_WEP) {
print_cipher_type(ap_info[i].pairwise_cipher, ap_info[i].group_cipher);
ESP_LOGI(TAG, "Channel \t\t%d\n", ap_info[i].primary);
