Page 1 of 3
Boot Linux on ESP32-S3
Posted: Wed May 17, 2023 3:29 am
by rudi ;-)
Hi Folks
After a few "ESP" apprenticeship years, I have arrived at my destination:
Booting Linux on an ESP32 directly.
if you want also try Boot Linux directly on an ESP32-S3 you could have a look to the fantastic Wiki by jcmvbkbc
Also there is born a Playground with diverse Things to come - and you perhabs want see too.
Booting Linux on ESP32-S3 -
It's working!
- done!
All the Best for you guys
greetings fly out to friends all over the globe
Best wishes
Re: Boot Linux on ESP32-S3
Posted: Thu May 18, 2023 4:24 am
by username
Thanks rudi for the update.
I have to ask... Wonder why they didn't choose 240mhz. looks like they have it set to 160mhz.
Lastly, though it boots, what can we really do with such limited ram?
Posted: Sun May 21, 2023 4:24 am
by rudi ;-)
i heard you, - here you are 240 MHz,
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 33
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: ccount: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7963585194 ns
[ 0.000081] sched_clock: 32 bits at 240MHz, resolution 4ns, wraps every 8947848189ns
[ 0.008099] Calibrating delay loop (skipped)... 240.00 BogoMIPS preset
[ 0.014307] pid_max: default: 4096 minimum: 301
[ 0.019108] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.026465] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.070816] rcu: Hierarchical SRCU implementation.
[ 0.071445] rcu: Max phase no-delay instances is 1000.
[ 0.083606] devtmpfs: initialized
the first hello world on the target you know?
it's a cross compiled rootfs,
done!
buildroot login: root
Password:
Jan 1 00:09:18 login[56]: root login on 'console'
~ # helloworld
Hello World
CPU count : 1
CPU list : 0
vendor_id : Tensilica
model : Xtensa LX7.0.12
core ID : LX7_ESP32_S3_MP
build ID : 0x90f1f
config ID : c2f0fffe:23090f1f
byte order : little
cpu MHz : 240.00
bogomips : 480.00
flags : nmi debug ocd density boolean loop nsa minmax sext clamps mac16 mul16 mul32 mul32h fpu s32c1i
physical aregs : 64
misc regs : 4
ibreak : 2
dbreak : 2
num ints : 32
ext ints : 26
int levels : 6
timers : 3
debug level : 6
icache line size: 4
icache ways : 1
icache size : 0
icache flags :
dcache line size: 16
dcache ways : 1
dcache size : 0
dcache flags :
Segmentation fault
also if too fast, 80MHz - we can switch. WoWZa 8-)
..we have a switching #PSRAMBANK btw..
also the second CPU is on the way
ps
you have an ESP32-S3-N8R8 ?
You want try? All things are online if you need.
Posted: Sun May 21, 2023 12:26 pm
by username
awesome! Next time I do my online order I'll pick one up and try.
Posted: Mon May 29, 2023 2:21 pm
by rudi ;-)
update:
29 May 2023
blinky , it's working fine.
Just in time happens: SDMC / USB Host ( mounting flash drive )
Next driver step: I2C / SPI
micropython port on S3Linux port
Posted: Sun Jul 09, 2023 10:29 am
by rudi ;-)
update:
- native micropython -just for show up- port
- linux port add to the boot partitions bootloader
hi folks
you can use micropython on this linux port
test firmware uploaded
example test:
ESP32-S3 with 16MB quad flash and 8 MB quad psram
example on m5stackCoreS3
- fw for your own test
ESP32-S3 with 8MB quad flash and 8 MB octal psram
example on
- ESP32-S3-DevKit N8R8
- olimex ESP32-S3-DevKit-Lipo OSHW board
the hello world ( blinky )
also the linux port was add to the boot partition bootloader
Posted: Wed Jul 12, 2023 1:55 pm
by rudi ;-)
update
WIFI on S3 Linux - your wireless connect
by using a small customized expanded ESP-Hosted
ping @ESPRESSIF
... done! 8-)
Posted: Thu Jul 27, 2023 7:58 pm
by rudi ;-)
update:
"SPECIALCLIENT ONLY" engineering WROOM sized ESP32-S3 ( without castellated holes )
ESP32-S3-WoWZa with
- N256R256
- N512R512
- N1GR1G
with castellated holes
pin compatible with ESP32-S2-SOLO, ESP32-S3-WROOM soon available for more testing and setups for Xtensa S3 Linux and ESP-IDF as well.
we get 256Mbit, 512Mbit and 1Gbit PSRAM Option now. the ESP32-S3 supports 1GB ( one giga byte ) PSRAM
as soon as possible the market has more as 1Gbit ( 128 mega byte ) available, i will update here :)
we are technical on market stand available now by 1/8 from what ESP32-S3 would be can do in one off-package.
JFYI: ESP32-S3 supports up to 1 GB off-package flash and 1 GB off-package RAM. If VDD_SPI is used to supply
power, make sure to select the appropriate off-package flash and RAM according to the power voltage on
VDD_SPI (1.8 V/3.3 V). It is recommended to add a zero-ohm series resistor on the SPI communication lines to
lower the driving current, reduce interference to RF, adjust timing, and better shield from interference.
Posted: Thu Aug 10, 2023 10:18 am
by rudi ;-)
update:
Remote Build by ESP32-S3 SSH Client which runs #jcmvbkbc #esp32s3 #linux #esp32 S3 port
10. Aug 2023
the YT Video shows all steps:
( JFYI: i did the same technic ( remote compile on an NFS/SSH Server ) june/2016 for the ESP8266
whats not new is - but new is, the Linux SSH client on the ESP32-S3 MCU can trigger this by self on demand
showing simple things by second SSH client which can be " a script" :D i hope you get the idea behind -
there is also now a 100GB NFS Share mountet which we use as executable space for the ESP32-S3 - and that is amazing!
we can run example 2 different mpy versions same time, the one from S3Linux userspace, and the second from the
"100GB Developer/cloud live compilation" - we see live the change of each compilation, not need any more,
rebuild rootfs ( userspace ) 100x and reflash ESP32-S3 - we do simple the Develop in the mounted CLOUD SPACE. :mrgreen:
  • remote build by ESP32-S3 SSH client which runs #jcmvbkbc #esp32s3 #linux #esp32 S3 port
  • ESP32-S3 runs #jcmvbkbc #esp32s3 #linux #esp32 S3 port which has also wifi and SSH support.
  • on the ESP32-S3 also runs native "posix" micropython and LUA ..
  • we connect from a PC by an SSH Client the ESP32-S3 (150) which runs a SSH Server.
  • the ESP32-S3 is also connected over wifi to the internet
  • we connect on ESP32-S3 ssh client internet timeserver and update local time on ESP32-S3.
  • we connect then cloud and mount the cloud to the ESP32-S3 as a shared folder which has 100GB space .
  • we serve to the cloud developer folder and cat the hi.c file.
  • we connect also a second putty ssh connection to the ESP32-S3 ssh server.
  • then we connect with the second ssh client on ESP32-S3 to the Developer Server (67) and serve to the cloud developer folder.
  • now we crosscompile the hi.c and run on the first ssh client the build
  • we do this moretime and patch also
  • last but not least ESP32-S3 runs binary build micropython from cloud share in the first ESP32-S3 client and also lua from ESP32-S3 userspace in the second SSH client same time..
( LUA YT Video ) also Micropyton installed
NFS Client runs on S3Linux and mounts a NFS Share (100GB) over WiFi
local console runs on wifi ssh server, 2 ssh clients connected per wifi and runs micropython port.
is this the world's first micropython server on a MCU?
Posted: Mon Aug 21, 2023 3:44 am
by yokonav
What are the steps to include micropython and lua when using the jcmvbkbc/rebuild-esp32s3-linux-wifi.sh script?
Thanks!
