"gpio.h" 2 differents files
Posted: Thu Oct 19, 2017 7:21 am
by mozufferey
If found two files with the name gpio.h which are located
1) ~esp-idf\components\driver\include\driver\gpio.h
2) ~esp\esp-idf\components\esp32\include\rom\gpio.h
In the SDK the two of them are clearly identify. e.g. in ~esp\esp-idf\components\driver\sdmmc_host.c
#include "rom/gpio.h"
#include "driver/gpio.h"
I found it however very dangerous. Maybe the less used should be renamed.
Re: "gpio.h" 2 differents files
Posted: Thu Nov 02, 2017 7:07 am
by mozufferey
I made some systematic analysis and found that many files are doubles, often same name with different content, I give here the full list as completion of this post. Note files and repository are alphabetic sorted.
_types.h
./newlib/include/machine/_types.h
./newlib/include/sys/_types.h
aes.h
./bt/bluedroid/stack/smp/include/aes.h
./esp32/include/hwcrypto/aes.h
./esp32/include/rom/aes.h
./mbedtls/include/mbedtls/aes.h
./wpa_supplicant/include/crypto/aes.h
allocator.h
./bt/bluedroid/osi/include/allocator.h
./nghttp/nghttp2/src/allocator.h
arc4.h
./lwip/include/lwip/netif/ppp/polarssl/arc4.h
./mbedtls/include/mbedtls/arc4.h
asn1.h
./mbedtls/include/mbedtls/asn1.h
./wpa_supplicant/include/wpa2/tls/asn1.h
aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/samples/linux/shadow_sample/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/samples/linux/shadow_sample_console_echo/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/samples/linux/subscribe_publish_cpp_sample/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/samples/linux/subscribe_publish_library_sample/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/samples/linux/subscribe_publish_sample/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/tests/integration/include/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/tests/unit/include/aws_iot_config.h
./aws_iot/aws-iot-device-sdk-embedded-C/include/aws_iot_error.h
./aws_iot/include/aws_iot_config.h
aws_iot_log.h
./aws_iot/aws-iot-device-sdk-embedded-C/include/aws_iot_log.h
./aws_iot/include/aws_iot_log.h
base64.h
./mbedtls/include/mbedtls/base64.h
./nghttp/nghttp2/src/base64.h
./wpa_supplicant/include/crypto/base64.h
./wpa_supplicant/include/wpa2/utils/base64.h
bignum.h
./mbedtls/include/mbedtls/bignum.h
./mbedtls/port/include/mbedtls/bignum.h
./wpa_supplicant/include/wpa2/tls/bignum.h
./wpa_supplicant/src/crypto/bignum.h
board.h
./esp32/include/xtensa/board.h
./esp32/include/xtensa/xtav110/xtensa/board.h
./esp32/include/xtensa/xtav200/xtensa/board.h
./esp32/include/xtensa/xtav60/xtensa/board.h
./esp32/include/xtensa/xtkc705/xtensa/board.h
./esp32/include/xtensa/xtml605/xtensa/board.h
bt_vendor_lib.h
./bt/bluedroid/hci/include/bt_vendor_lib.h
./bt/bluedroid/include/bt_vendor_lib.h
buffer.h
./bt/bluedroid/osi/include/buffer.h
./nghttp/nghttp2/src/buffer.h
coap_config.h
./coap/libcoap/examples/contiki/coap_config.h
./coap/libcoap/examples/lwip/coap_config.h
common.h
./libsodium/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/common.h
./libsodium/libsodium/src/libsodium/include/sodium/private/common.h
./nghttp/nghttp2/third-party/mruby/include/mruby/common.h
./wpa_supplicant/include/crypto/common.h
./wpa_supplicant/include/wpa/common.h
config.h
./bt/bluedroid/osi/include/config.h
./mbedtls/include/mbedtls/config.h
./newlib/include/config.h
./newlib/include/sys/config.h
./nghttp/port/include/config.h
core.h
./esp32/include/xtensa/config/core.h
./libsodium/libsodium/src/libsodium/include/sodium/core.h
core-isa.h
./esp32/include/xtensa/config/core-isa.h
./newlib/include/xtensa/config/core-isa.h
crc.h
./esp32/include/rom/crc.h
./nvs_flash/test_nvs_host/crc.h
debug.h
./coap/libcoap/include/coap/debug.h
./lwip/include/lwip/lwip/debug.h
./mbedtls/include/mbedtls/debug.h
./nghttp/nghttp2/third-party/mruby/include/mruby/debug.h
defs.h
./esp32/include/xtensa/config/defs.h
./wpa_supplicant/include/wpa/defs.h
des.h
./lwip/include/lwip/netif/ppp/polarssl/des.h
./mbedtls/include/mbedtls/des.h
eap.h
./lwip/include/lwip/netif/ppp/eap.h
./wpa_supplicant/include/wpa2/eap_peer/eap.h
ecp.h
./lwip/include/lwip/netif/ppp/ecp.h
./mbedtls/include/mbedtls/ecp.h
endian.h
./newlib/include/machine/endian.h
./wpa_supplicant/port/include/endian.h
errno.h
./newlib/include/errno.h
./newlib/include/sys/errno.h
error.h
./nghttp/nghttp2/src/shrpx_error.h
./nghttp/nghttp2/third-party/mruby/include/mruby/error.h
./nghttp/nghttp2/third-party/mruby/src/error.h
gpio.h
./driver/include/driver/gpio.h
./esp32/include/rom/gpio.h
ieeefp.h
./newlib/include/ieeefp.h
./newlib/include/machine/ieeefp.h
includes.h
./wpa_supplicant/include/crypto/includes.h
./wpa_supplicant/include/wpa/includes.h
inet.h
./lwip/include/lwip/lwip/inet.h
./lwip/include/lwip/port/arpa/inet.h
jsmn.h
./aws_iot/aws-iot-device-sdk-embedded-C/external_libs/jsmn/jsmn.h
./jsmn/include/jsmn.h
libtommath.h
./wpa_supplicant/include/wpa2/tls/libtommath.h
./wpa_supplicant/src/crypto/libtommath.h
list.h
./bt/bluedroid/osi/include/list.h
./freertos/include/freertos/list.h
./wpa_supplicant/include/wpa/list.h
lwipopts.h
./coap/libcoap/examples/lwip/lwipopts.h
./lwip/include/lwip/port/lwipopts.h
malloc.h
./newlib/include/machine/malloc.h
./newlib/include/malloc.h
md4.h
./lwip/include/lwip/netif/ppp/polarssl/md4.h
./mbedtls/include/mbedtls/md4.h
md5.h
./lwip/include/lwip/netif/ppp/polarssl/md5.h
./mbedtls/include/mbedtls/md5.h
./wpa_supplicant/include/crypto/md5.h
mem.h
./coap/libcoap/include/coap/mem.h
./lwip/include/lwip/lwip/mem.h
miniz.h
./esp32/include/rom/miniz.h
./esptool_py/esptool/flasher_stub/miniz.h
net.h
./coap/libcoap/include/coap/net.h
./mbedtls/include/mbedtls/net.h
netdb.h
./lwip/include/lwip/lwip/netdb.h
./lwip/include/lwip/posix/netdb.h
network_platform.h
./aws_iot/aws-iot-device-sdk-embedded-C/platform/linux/mbedtls/network_platform.h
./aws_iot/aws-iot-device-sdk-embedded-C/tests/unit/tls_mock/network_platform.h
./aws_iot/include/network_platform.h
opcode.h
./nghttp/nghttp2/third-party/mruby/include/mruby/opcode.h
./nghttp/nghttp2/third-party/mruby/src/opcode.h
param.h
./newlib/include/machine/param.h
./newlib/include/sys/param.h
phy.h
./esp32/phy.h
./ethernet/include/eth_phy/phy.h
pkcs5.h
./mbedtls/include/mbedtls/pkcs5.h
./wpa_supplicant/include/wpa2/tls/pkcs5.h
queue.h
./esp32/include/rom/queue.h
./freertos/include/freertos/queue.h
./newlib/include/sys/queue.h
random.h
./nghttp/nghttp2/third-party/mruby/mrbgems/mruby-random/src/random.h
./wpa_supplicant/include/crypto/random.h
reent.h
./newlib/include/reent.h
./newlib/include/sys/reent.h
resource.h
./newlib/include/sys/resource.h
./coap/libcoap/include/coap/resource.h
rsa.h
./mbedtls/include/mbedtls/rsa.h
./wpa_supplicant/include/wpa2/tls/rsa.h
rtc.h
./esp32/include/rom/rtc.h
./soc/esp32/include/soc/rtc.h
sched.h
./newlib/include/sched.h
./newlib/include/sys/sched.h
sdkconfig.h
./nvs_flash/test_nvs_host/sdkconfig.h
./wear_levelling/test_wl_host/sdkconfig.h
setjmp.h
./newlib/include/machine/setjmp.h
./newlib/include/setjmp.h
sha.h
./esp32/include/hwcrypto/sha.h
./esp32/include/rom/sha.h
sha1.h
./lwip/include/lwip/netif/ppp/polarssl/sha1.h
./mbedtls/include/mbedtls/sha1.h
./wpa_supplicant/include/crypto/sha1.h
signal.h
./newlib/include/signal.h
./newlib/include/sys/signal.h
specreg.h
./esp32/include/xtensa/config/specreg.h
./esp32/include/xtensa/specreg.h
ssl.h
./mbedtls/include/mbedtls/ssl.h
./openssl/include/openssl/ssl.h
stdio.h
./newlib/include/stdio.h
./newlib/include/sys/stdio.h
stdlib.h
./newlib/include/machine/stdlib.h
./newlib/include/stdlib.h
string.h
./newlib/include/string.h
./newlib/include/sys/string.h
./nghttp/nghttp2/third-party/mruby/include/mruby/string.h
termios.h
./newlib/include/termios.h
./newlib/include/machine/termios.h
threads_platform.h
./aws_iot/aws-iot-device-sdk-embedded-C/platform/linux/pthread/threads_platform.h
./aws_iot/include/threads_platform.h
time.h
./newlib/include/machine/time.h
./newlib/include/sys/time.h
./newlib/include/time.h
timers.h
./freertos/include/freertos/timers.h
./lwip/include/lwip/lwip/timers.h
tls.h
./nghttp/nghttp2/src/tls.h
./wpa_supplicant/include/wpa2/tls/tls.h
trax.h
./esp32/include/xtensa/trax.h
./xtensa-debug-module/include/trax.h
types.h
./micro-ecc/micro-ecc/types.h
./newlib/include/machine/types.h
./newlib/include/sys/types.h
u0.h
./libsodium/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/u0.h
./libsodium/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/u0.h
u1.h
./libsodium/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/u1.h
./libsodium/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/u1.h
u4.h
./libsodium/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/u4.h
./libsodium/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/u4.h
u8.h
./libsodium/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/u8.h
./libsodium/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/u8.h
uart.h
./driver/include/driver/uart.h
./esp32/include/rom/uart.h
unistd.h
./newlib/include/sys/unistd.h
./newlib/include/unistd.h
utime.h
./newlib/include/sys/utime.h
./newlib/include/utime.h
version.h
./aws_iot/aws-iot-device-sdk-embedded-C/include/aws_iot_version.h
./bt/bluedroid/btcore/include/version.h
./libsodium/libsodium/builds/msvc/version.h
./libsodium/port_include/sodium/version.h
./mbedtls/include/mbedtls/version.h
./nghttp/nghttp2/third-party/mruby/include/mruby/version.h
Posted: Sat Nov 04, 2017 4:42 pm
by Sprite
What's your reasoning to think this is 'very dangerous'?
