VDD_SDIO when CHIP_PU low
smantila
Postby smantila » Thu Oct 19, 2017 9:49 am
What happens to VDD_SDIO when CHIP_PU is pulled low?
We are planning to use ESP-WROOM-32 module and we would connect QSPI flash pins (GPIO6-11) from ESP module to main application processor for easy flash updating. Plan is to put CHIP_PU low so that ESP32 is not using flash and update QSPI flash with external SPI access. Problem is that VDD_SDIO is internal to module and it is connected to QSPI flash. Would our idea work or is VDD_SDIO shutdown when CHIP_PU is low?
Angus
Re: VDD_SDIO when CHIP_PU low
Postby Angus » Fri Oct 27, 2017 10:36 am
Sorry for the slow reply. I consulted with our hardware team who confirmed this should be fine. VDD_SDIO regulator is disabled when CHIP_PU (aka EN) is low and applying external voltage to the pin when the regulator is disabled is not a problem.
We recommend maintaining the normal VDD 3.3V input voltages to the ESP32 at this time, though (to avoid parasitic powering of the chip).
Angus
taribo
Postby taribo » Thu Nov 02, 2017 8:28 am
Hi ESP_Angus,
So you are saying that we should apply external (3.3V) voltage to VDD_SDIO pin of the ESP32 chip ?
But for the ESP-WROOM-32 module, this pin (VDD_SDIO) is not present externally. For ESP-WROOM-32 module, VDD_SDIO pin is only internally connected to flash chip. This connection is under the metallic RF shield.
So the question is: how can we power the flash of the ESP-WROOM-32 module, when we keep the ESP32 chip in power down (CHIP_PU low) ?
Users browsing this forum: ChatGPT-User, trendictionbot and 3 guests
