I have an esp32s3 project that stopped working abruptly. Every project with wifi and camera, the camera doesnt stream anymore even though it is working and wifi can be connected. The "enable streaming" function on menuconfig is missing without cause.
Even when I took my board with working code to just monitoring (idf.py -p COM6 monitor), it shows garbage info instead of what was supposed to, as you can see in the print.
Espressif update
Espressif update
- esp_update.png (104.55 KiB) Viewed 1149 times
- jgustavoam
- Contact:
Re: Espressif update
Izadora, Explain in more detail please.izadoraberti wrote: ↑Fri Jun 02, 2023 9:08 pmI have an esp32s3 project that stopped working abruptly.
What did you do on your project?
Did you compile with a new version of IDF? Which was the previous version and which is in use.
Retired IBM Brasil
esp-idf-v5.0.1 and older version also
Users browsing this forum: No registered users and 206 guests
