请问如何使用flask替换pipeline_raw_http示例中的server.py?
Posted: Sat Jun 10, 2023 11:58 am
您好,我正在尝试将pipeline_raw_http示例对接到flask 服务器上,按照server.py重构后的代码如下:
然而当代码运行到 _get_chunk_size() 时,使用request.stream.read()并不能像server.py中使用rfile.read()一样获取到正确的chunksize,而是获取到了与server.py中_get_chunk_data( chunk_size)类似的16bit音频流,似乎在request.stream.read()运行时有一部分数据流被跳过了。
请问这是什么原因?除了使用http stream 以外还有什么办法能将音频传输到后端?
import datetime
import wave
from flask import Flask, request, Response
import sys
app = Flask(__name__)
def _get_chunk_size():
data = request.stream.read(2)
print(type(data))
while data[-2:] != b"\r\n":
data += request.stream.read(1)
return int(data[:-2], 16)
def _get_chunk_data( chunk_size):
data = request.stream.read(chunk_size)
return data
def _write_wav( data, rates, bits, ch):
t = datetime.datetime.utcnow()
time = t.strftime('%Y%m%dT%H%M%SZ')
filename = str.format('{}_{}_{}_{}.wav', time, rates, bits, ch)
wavfile = wave.open(filename, 'wb')
wavfile.setparams((ch, int(bits/8), rates, 0, 'NONE', 'NONE'))
wavfile.writeframesraw(bytearray(data))
wavfile.close()
return filename
@app.route('/')
def hello_world():
return 'Hello, World!'
@app.route("/upload", methods=["POST"])
def upload():
total_bytes = 0
sample_rates = 0
bits = 0
channel = 0
if request.headers.get('Transfer-Encoding').lower() == 'chunked':
data = []
sample_rates = request.headers.get('x-audio-sample-rates', '').lower()
bits = request.headers.get('x-audio-bits', '').lower()
channel = request.headers.get('x-audio-channel', '').lower()
print("Audio information, sample rates: {}, bits: {}, channel(s): {}".format(sample_rates, bits, channel))
while True:
chunk_size = _get_chunk_size()
total_bytes += chunk_size
print("Total bytes received: {}".format(total_bytes))
sys.stdout.write("\033[F")
if (chunk_size == 0):
break
else:
chunk_data = _get_chunk_data(chunk_size)
data += chunk_data
filename = _write_wav(data, int(sample_rates), int(bits), int(channel))
def generate():
yield 'File {} was written, size {}'.format(filename, total_bytes).encode('utf-8')
response = Response(generate(), mimetype='text/html')
response.status_code = 200
response.headers['Content-type'] = 'text/html;charset=utf-8'
response.headers['Content-Length'] = str(total_bytes)
return response
if __name__ == '__main__':
app.run(host='0.0.0.0', port=8000, debug=True)请问这是什么原因?除了使用http stream 以外还有什么办法能将音频传输到后端?
