ESP32-C3-DevkitM-1 and ESP-PROG and Platformio and VSCODE (Win10) problems
joseMiguel
Postby joseMiguel » Wed Jun 14, 2023 1:30 pm
I am trying to debug ESP32-C3-DevkitM-1 board with ESP-PROG debugger.
(I have already used built-in USB/JTAG interface, but i faced lot of problems with freertos, so i decided to go trough ESP-PROG)
1) I have burned the DIS_USB_JTAG fuse by typing :
>espefuse.py --port COM11 burn_efuse DIS_JTAG_USB 1
2) I have connected GPIO10 to +3.3V
and ESP-PROG to ESP32-C3-DevkitM-1
ESP-PROG <---------> ESP32-C3-DevkitM-1
(Pin 2) ESP_TMS <---------> (Pin 11 right side) MTMS
(Pin 4) ESP_TCK <---------> (Pin 9 right side) MTCK
(Pin 6) ESP_TDO <---------> (Pin 8 right side) MTDO
(Pin 8) ESP_TDI <---------> (Pin 10 right side) MTDI
remark :
in the schematic the ESP-PROG, ESP_TDO is an input and ESP_TDI is an output.
3) I have used the Zadig software (Dual RS232-HS (interface 0) replaced by WinUsb)
I have the following message in the DEBUG CONSOLE
undefinedC:\Users\josem\.platformio\packages\toolchain-riscv32-esp\bin\riscv32-esp-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from c:\Users\josem\espidf-Platformio-Projects\testProjet1\.pio\build\esp32-c3-devkitm-1\firmware.elf...
PlatformIO Unified Debugger -> https://bit.ly/pio-debug
PlatformIO: debug_tool = esp-prog
PlatformIO: Initializing remote target...
Open On-Chip Debugger  v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Error: Unsupported DTM version: 14
Warn : target esp32c3 examination failed
Info : starting gdb server for esp32c3 on pipe
Info : accepting 'gdb' connection from pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32c3:
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Error: Unsupported xlen: -1
Error: Unknown target arch!
.pioinit:11: Error in sourced command file:
Remote communication error.  Target disconnected.: Success.
here below my platformio.ini file
[env:esp32-c3-devkitm-1]
platform = espressif32
board = esp32-c3-devkitm-1
framework = espidf
upload_port = COM11
monitor_speed = 115200
; [debug_openocd]
; debug_server =
;     ${platformio.packages_dir}/tool-openocd-esp32/bin
;     -s
;     ${platformio.packages_dir}/tool-openocd-esp32/share/openocd/scripts/
;     -f
;     ${platformio.packages_dir}/tool-openocd-esp32/share/openocd/scripts/board/esp32c3-ftdi.cfg
; [debug]
; debug_server =
;     ${platformio.packages_dir}\\toolchain-riscv32-esp\\bin
;     -singlerun
;     -if
;     JTAG
;     ;ftdi
;     -select
;     JTAG
;     -port
;     localhost:3333
;     -device
;     esp32c3
debug_init_break = tbreak app_main
Could you help me please,
Thank you in advance
kind regards
José Miguel
José Michel
joseMiguel
Re: ESP32-C3-DevkitM-1 and ESP-PROG and Platformio and VSCODE (Win10) problems
Postby joseMiguel » Sat Dec 30, 2023 4:00 pm
For those who want to use Platformio and the ESP_PROG debugger on Win10
I give your my platformio.ini who works
framework = espidf
; Set optimization level and amount of debug information generated by the compiler
debug_build_flags = -O0 -ggdb3 -g3
; JMJ tests two lines below
build_flags = -D PIO_FRAMEWORK_MBED_RTOS_PRESENT
lib_ldf_mode = chain+
upload_port = COM11
; fixed speed in kHz
debug_speed = 8000
[debug_openocd]
debug_server =
    -s
    -f
    -c 'usb_vid_pid 0x0403 0x6010'
    ;ftdi tdo_sample_edge falling
[debug]
debug_server =
    -singlerun
    -if
    ;JTAG
    ftdi
    -select
    JTAG
    -port
    localhost:3333
    -device
    esp32c3
Have a nice end of year
Regards
José Michel
José Michel
Users browsing this forum: ChatGPT-User, Google [Bot] and 8 guests
