I would like to bond the Watchy via BLE to my Android phone to support Android Smart Lock.
Posted: Sun Jun 18, 2023 11:06 am
I would like to bond my Watchy via BLE to my Android phone to support Android Smart Lock. After bonding the Watch could advertise simply to keep the Smart Lock active on the phone.
Created a BLE method:
GATT Event Handler:
GAP Event Handler:
Security Callback Handler:
Callback to catch the BLE Characteristic:
BLE Server Callback:
At the end the Android phone requests the user to confirm pairing.
But afterwards the BLE trace in nrfConnect shown GATT Insufficient Authorization when trying to update the BLE connection after previous successful connect and characteristics discovery.
Any experiences with bonding the Watchy to Android smartphone?
bool BLE_Bond::begin(const char localName = "Watchy") {
BLEDevice::setCustomGattcHandler(gattcEventHandler);
// Create the BLE Device
BLEDevice::init(localName);
BLEDevice::setCustomGapHandler(my_gap_event_handler);
// Create the BLE Server
pServer = BLEDevice::createServer();
BLEDevice::setEncryptionLevel(ESP_BLE_SEC_ENCRYPT);
BLEDevice::setSecurityCallbacks(new MySecurity());
pServer->setCallbacks(new BLECustomServerCallbacks());
// Create the BLE Service
pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setAccessPermissions(ESP_GATT_PERM_READ_ENCRYPTED | ESP_GATT_PERM_WRITE_ENCRYPTED);
pCharacteristic->setValue("Hello World says Watchy");
pCharacteristic->addDescriptor(new BLE2902());
pCharacteristic->setCallbacks(new bondCallback(this));
// Start the service(s)
pService->start();
// Start advertising
BLEAdvertisingpAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(true);
pAdvertising->setMinPreferred(0x12); // set value to 0x00 to not advertise this parameter
pAdvertising->start();
BLESecurity *pSecurity = new BLESecurity();
pSecurity->setAuthenticationMode(ESP_LE_AUTH_REQ_SC_BOND);
pSecurity->setCapability(ESP_IO_CAP_NONE);
uint8_t init_key = ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK;
esp_ble_gap_set_security_param(ESP_BLE_SM_SET_INIT_KEY, &init_key, sizeof(uint8_t));
pSecurity->setInitEncryptionKey(ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK);
return true;
}Code: Select all
void gattcEventHandler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param)
if (event == ESP_GATTC_DISCONNECT_EVT) {
bondStatus = BOND_STATUS_GATTDISCONNECT;
} else
if (event == ESP_GATTC_CONNECT_EVT) {
esp_ble_set_encryption(param->connect.remote_bda, ESP_BLE_SEC_ENCRYPT);
bondStatus = BOND_STATUS_GATTCONNECT;
}Code: Select all
static void my_gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t* param) {
switch(event){
case ESP_GAP_BLE_AUTH_CMPL_EVT:{ // last called
BLEAddress address = BLEAddress(param->ble_security.auth_cmpl.bd_addr);
BLEDevice::whiteListAdd(address);
bondStatus = BOND_STATUS_AUTHCOMPLETE;
break;
case ESP_GAP_BLE_SEC_REQ_EVT:{
esp_ble_gap_security_rsp(param->ble_security.ble_req.bd_addr, true);
bondStatus = BOND_STATUS_SECURITYEVT;
break;
case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:{
bondStatus = BOND_STATUS_UPDATECONNPARAMS;
break;
}Code: Select all
class MySecurity : public BLESecurityCallbacks {
bool onConfirmPIN(uint32_t pin){
return true;
uint32_t onPassKeyRequest(){
return 0;
void onPassKeyNotify(uint32_t pass_key){
bool onSecurityRequest(){
return true;
// called with failed
void onAuthenticationComplete(esp_ble_auth_cmpl_t cmpl){
if(cmpl.success){
bondStatus = BOND_STATUS_BONDED;
else{
bondStatus = BOND_STATUS_FAILED;
bondErrorCode = cmpl.fail_reason;
};Code: Select all
class bondCallback : public BLECharacteristicCallbacks {
public:
bondCallback(BLE_Bond ble) {
_p_ble = ble;
BLE_Bond_p_ble;
};Code: Select all
class BLECustomServerCallbacks : public BLEServerCallbacks {
void onConnect(BLEServer pServer) {
bondStatus = BOND_STATUS_CONNECTED;
pServer->getAdvertising()->start();
void onDisconnect(BLEServerpServer) {
bondStatus = BOND_STATUS_DISCONNECTED;
};But afterwards the BLE trace in nrfConnect shown GATT Insufficient Authorization when trying to update the BLE connection after previous successful connect and characteristics discovery.
