* @FilePath: wifimesh32_lite.c
* @Author: jack
* @Date: 2023-06-16 16:21:58
* @LastEditors:
* @LastEditTime: 2023-06-16 16:21:58
* @Copyright: 2023 xxxTech CO.,LTD. All Rights Reserved.
* @Descripttion:
#include <inttypes.h>
#include "wifimesh32_lite.h"
extern esp_ip4_addr_t mqtt_send_ip;
static void ip_event_sta_got_ip_handler(void *arg, esp_event_base_t event_base,
int32_t event_id, void *event_data)
ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
ESP_LOGI("mesh_lite_ay", "<mesh获取到>IP:" IPSTR, IP2STR(&event->ip_info.ip));
mqtt_send_ip.addr = event->ip_info.ip.addr;
// #if !CONFIG_MESH_USE_GLOBAL_DNS_IP
// esp_netif_t *netif = event->esp_netif;
// esp_netif_dns_info_t dns;
// ESP_ERROR_CHECK(esp_netif_get_dns_info(netif, ESP_NETIF_DNS_MAIN, &dns));
// mesh_netif_start_root_ap(esp_mesh_is_root(), dns.ip.u_addr.ip4.addr);
// #endif
mainuser();
vTaskDelay(1000);
// mqtt_app_start();
DEVICEINFO.devicestatus = ping_mqtt_yes;
// mainuser();
// esp_mesh_comm_mqtt_task_start();
// example_start_file_server("/rdy");
static esp_err_t wifi_init(void)
// Station
wifi_config_t wifi_config;
strcpy((char *)wifi_config.sta.ssid, DEVICEINFO.wifi_infometion.ssid);
strcpy((char *)wifi_config.sta.password, DEVICEINFO.wifi_infometion.password);
esp_bridge_wifi_set(WIFI_MODE_STA, (char *)wifi_config.sta.ssid, (char *)wifi_config.sta.password, NULL);
// // Softap
memset(&wifi_config, 0x0, sizeof(wifi_config_t));
// size_t softap_ssid_len = sizeof(wifi_config.ap.ssid);
// if (esp_mesh_lite_get_softap_ssid_from_nvs((char *)wifi_config.ap.ssid, &softap_ssid_len) != ESP_OK)
snprintf((char *)wifi_config.ap.ssid, sizeof(wifi_config.ap.ssid), "%s", CONFIG_BRIDGE_SOFTAP_SSID);
// size_t softap_psw_len = sizeof(wifi_config.ap.password);
// if (esp_mesh_lite_get_softap_psw_from_nvs((char *)wifi_config.ap.password, &softap_psw_len) != ESP_OK)
strlcpy((char *)wifi_config.ap.password, CONFIG_BRIDGE_SOFTAP_PASSWORD, sizeof(wifi_config.ap.password));
esp_bridge_wifi_set(WIFI_MODE_AP, (char *)wifi_config.ap.ssid, (char *)wifi_config.ap.password, NULL);
return ESP_OK;
void print_task_memory(void)
char *task_list_buffer;
UBaseType_t task_count = uxTaskGetNumberOfTasks();
task_list_buffer = malloc(task_count * sizeof(TaskStatus_t));
vTaskList(task_list_buffer);
printf("Task Name\t\tStack High Water Mark\n");
printf("----------------------------------------\n");
TaskStatus_t *task_status_array = (TaskStatus_t *)task_list_buffer;
for (int i = 0; i < task_count; i++)
printf("%s\t\t%d words\n", task_status_array[i].pcTaskName, task_status_array[i].usStackHighWaterMark);
free(task_list_buffer);
void tt(void)
char *test;
test = malloc(1000);
void wifi_lite(void *p)
esp_bridge_create_all_netif();
wifi_init();
esp_mesh_lite_config_t mesh_lite_config = ESP_MESH_LITE_DEFAULT_INIT();
strcpy(mesh_lite_config.device_category, "mjk");
esp_mesh_lite_init(&mesh_lite_config);
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &ip_event_sta_got_ip_handler, NULL, NULL));
int m = 0;
while (1)
// printf("wifi_lite\r\n");
// print_task_memory();
m = m + 2;
vTaskDelay(100);
void wifimesh_lite(void)
xTaskCreatePinnedToCore(wifi_lite, "wifi_lite", 10240, NULL, 5, NULL, 0);
