I have the electrical connections as described, i.e.
20 --> D+ (green)
19 --> D- (white)
Ca. 2 months ago, I managed to flash the ESP32-S3 via USB several times by simply navigating to my "bleprph" example project folder and then running from the command line the following command :
/home/boko/.espressif/python_env/idf5.1_py3.10_env/bin/python /home/boko/esp/esp-idf/tools/idf.py dfu dfu-flash
Now, I can't. When I try the same command, it fails with the following error messages:
~/Desktop/ESP32/esp32_spraykit/bleprph$ /home/boko/.espressif/python_env/idf5.1_py3.10_env/bin/python /home/boko/esp/esp-idf/tools/idf.py dfu
Setting IDF_PATH environment variable: /home/boko/esp/esp-idf
Adding "dfu"'s dependency "all" to list of commands with default set of options.
Executing action: all (aliases: build)
Running cmake in directory /home/boko/Desktop/ESP32/esp32_spraykit/bleprph/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=/home/boko/.espressif/python_env/idf5.1_py3.10_env/bin/python -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=0 /home/boko/Desktop/ESP32/esp32_spraykit/bleprph"...
-- Found Git: /usr/bin/git (found version "2.34.1")
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: xtensa-esp32s3-elf-gcc
CMake Error at /home/boko/esp/esp-idf/tools/cmake/project.cmake:342 (__project):
The CMAKE_C_COMPILER:
is not a full path and was not found in the PATH.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
CMakeLists.txt:9 (project)
The CMAKE_CXX_COMPILER:
xtensa-esp32s3-elf-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
The CMAKE_ASM_COMPILER:
variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
-- Warning: Did not find file Compiler/-ASM
See also "/home/boko/Desktop/ESP32/esp32_spraykit/bleprph/build/CMakeFiles/CMakeOutput.log".
See also "/home/boko/Desktop/ESP32/esp32_spraykit/bleprph/build/CMakeFiles/CMakeError.log".
HINT: Try to reinstall the toolchain for the chip that you trying to use.
For more information run 'idf.py docs -sp get-started/#installation' and follow the instructions for your system
cmake failed with exit code 1, output of the command is in the /home/boko/Desktop/ESP32/esp32_spraykit/bleprph/build/log/idf_py_stderr_output_76127 and /home/boko/Desktop/ESP32/esp32_spraykit/bleprph/build/log/idf_py_stdout_output_76127
boko@hp-elitebook-850-g8:~/Desktop/ESP32/esp32_spraykit/bleprph$Trying to set the target by typing in the command line
/home/boko/.espressif/python_env/idf5.1_py3.10_env/bin/python /home/boko/esp/esp-idf/tools/idf.py set-target esp32s3Any help or hint about how to solve the issue would be appreciated
P.S. I can build and flash via UART the same project, so the C compiler and ASM compiler issue does not manifest via UART, only via USB.
