I am looking for some sample code that will simply capture the state of a GPIO pin and build the bitstream in the DMA buffer.
I need to capture at 40MHz (25ns intervals). Everything i have seen deals with audio data, and I need to make just a very simple single channel logic analyzer with 2 buffers so that a continuous stream can be stored in PSRAM (using ping-pong buffers).
Thanks!
Simple sample code for GPIO capture using I2S?
Re: Simple sample code for GPIO capture using I2S?
Hi
This is a bit different from what you want.
Parallel capture at 40 megahertz
but if you wish, you can correct it for serial as far as I understand
https://esp32.com/viewtopic.php?f=17&t=33876
Thanks for pointing this out!
Does this use I2S for the capture? I don't need 16 channels.. I need just 1 channel, but I do need to capture 300,000 samples and store them in PSRAM.
