coredump怎么使用?
Posted: Mon Jul 03, 2023 3:57 am
环境:window11 vscode
版本库:v5.0-rc1*
我按ESP--FAQ文档来使用coredump
https://docs.espressif.com/projects/esp ... 2-coredump
在执行espcoredump.py info_corefile -t elf -c coredump.bin C:\Users\15119\esp\Code008_ESPS32\build\Code008.elf时.
出现了以下问题:
查阅了网上的其他案例,有的说是4.3之后就会出现这个问题。
请问这个问题要如果解决?谢谢
版本库:v5.0-rc1*
出现了以下问题:
Code: Untitled.c Select all
File "C:\Users\15119\esp\esp-idf\components\espcoredump\espcoredump.py", line 77, in <module>
main()
File "C:\Users\15119\esp\esp-idf\components\espcoredump\espcoredump.py", line 62, in main
temp_core_files = espcoredump.info_corefile()
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esp_coredump\coredump.py", line 398, in info_corefile
self.core_elf = ESPCoreDumpElfFile(core_elf_path)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esp_coredump\corefile\elf.py", line 309, in __init__
super(ESPCoreDumpElfFile, self).__init__(elf_path, _e_type, _e_machine)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esp_coredump\corefile\elf.py", line 117, in __init__
self.read_elf(elf_path)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esp_coredump\corefile\elf.py", line 128, in read_elf
header_tables = ElfHeaderTables.parse(elf_bytes)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 288, in parse
return self.parse_stream(io.BytesIO(data), **contextkw)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 300, in parse_stream
return self._parsereport(stream, context, "(parsing)")
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 312, in _parsereport
obj = self._parse(stream, context, path)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 2120, in _parse
subobj = sc._parsereport(stream, context, path)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 2653, in _parse
return self.subcon._parsereport(stream, context, path)
File "C:\Users\15119\.espressif\python_env\idf5.0_py3.8_env\lib\site-packages\construct\core.py", line 2728, in _parse
raise ConstError(f"parsing expected {repr(self.value)} but parsed {repr(obj)}", path=path)
construct.core.ConstError: Error in path (parsing) -> elf_header -> e_ident -> EI_MAG
parsing expected b'\x7fELF' but parsed b'\xe4\x1c\x00\x00'请问这个问题要如果解决?谢谢
