Hello
I am using ESP32-S3 WROOM FREENOVE with camera OV2640 (supposed to be an upgrade from AI-Thinker ESP-CAM)
uploading this code CameraWebServer
I am using Arduino IDE with these settings -
Board - ESP32S3 dev module
Flash size 8MB
Partition - HUGE APP
PSRAM -QSPI PSRAM
FQBN: esp32:esp32:esp32s3:PSRAM=enabled,FlashSize=8M,PartitionScheme=huge_app,DebugLevel=info
I am getting unstable results. PSRAM init failed error
sometimes cannot connect to WIFI.
please recommend the correct settings for Arduino IDE
Thanks!
Build:Mar 27 2021
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbe4
load:0x403cc700,len:0x2a38
entry 0x403c98d4
E (519) esp_core_dump_flash: No core dump partition found!
E (521) psram: PSRAM ID read error: 0x00ffffff
[ 522][W][esp32-hal-psram.c:71] psramInit(): PSRAM init failed!
WiFi connected
[ 1311][app_httpd.cpp:1360] startCameraServer(): [] Starting web server on port: '80'
[ 1314][app_httpd.cpp:1378] startCameraServer(): [] Starting stream server on port: '81'
Camera Ready! Use 'http://132.68.34.71' to connect
FREENOVE ESP32-S3 Camera board settings
Re: FREENOVE ESP32-S3 Camera board settings
Hello
Try OPI PSRAM
And for wifi ... same problem I order one 6 month ago, it never connect but quick replace by seller, the new connect but not stable
Try OPI PSRAM
