运行espefuse.py burn_efuse FLASH_CRYPT_CNT命令,结果失败了
espefuse.py v4.5.1
Connecting.......
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Detecting chip type... ESP32
=== Run "burn_efuse" command ===
The efuses to burn:
from BLOCK0
- FLASH_CRYPT_CNT
Burning efuses:
- 'FLASH_CRYPT_CNT' (Flash encryption mode counter) 0b0000001 -> 0b0000011
Check all blocks for burn...
idx, BLOCK_NAME, Conclusion
[00] BLOCK0 is not empty
(written ): 0x00000344f0100000000006340000a200009324d7eb5d08d400110080
(to write): 0x00000000000000000000000000000000000000000000000000300000
(coding scheme = NONE)
This is an irreversible operation!
Type 'BURN' (all capitals) to continue.
运行espefuse.py -p COM6 summary查看状态如下
看起来是FLASH_CRYPT_CNT被写保护,但是我看文档默认是未写保护的,我这里按照flash_encryption示例程序做的,应该没有操作过写保护,我的操作哪里有问题么?=== Run "summary" command ===
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
BLK3_PART_RESERVE (BLOCK0): BLOCK3 partially served for ADC calibration data = False R/W (0b0)
ADC_VREF (BLOCK0): Voltage reference calibration = 1142 R/W (0b00110)
Config fuses:
XPD_SDIO_FORCE (BLOCK0): Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = False R/W (0b0)
XPD_SDIO_REG (BLOCK0): If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0): If XPD_SDIO_FORCE & XPD_SDIO_REG = 1.8V R/W (0b0)
CLK8M_FREQ (BLOCK0): 8MHz clock freq override = 52 R/W (0x34)
SPI_PAD_CONFIG_CLK (BLOCK0): Override SD_CLK pad (GPIO6/SPICLK) = 0 R/W (0b00000)
SPI_PAD_CONFIG_Q (BLOCK0): Override SD_DATA_0 pad (GPIO7/SPIQ) = 0 R/W (0b00000)
SPI_PAD_CONFIG_D (BLOCK0): Override SD_DATA_1 pad (GPIO8/SPID) = 0 R/W (0b00000)
SPI_PAD_CONFIG_HD (BLOCK0): Override SD_DATA_2 pad (GPIO9/SPIHD) = 0 R/W (0b00000)
SPI_PAD_CONFIG_CS0 (BLOCK0): Override SD_CMD pad (GPIO11/SPICS0) = 0 R/W (0b00000)
DISABLE_SDIO_HOST (BLOCK0): Disable SDIO host = False R/W (0b0)
Efuse fuses:
WR_DIS (BLOCK0): Efuse write disable mask = 128 R/W (0x0080)
RD_DIS (BLOCK0): Efuse read disable mask = 1 R/W (0x1)
CODING_SCHEME (BLOCK0): Efuse variable block length scheme
= NONE (BLK1-3 len=256 bits) R/W (0b00)
KEY_STATUS (BLOCK0): Usage of efuse block 3 (reserved) = False R/W (0b0)
Identity fuses:
MAC (BLOCK0): Factory MAC Address
= 24:d7:eb:5d:08:d4 (CRC 0x93 OK) R/W
MAC_CRC (BLOCK0): CRC8 for factory MAC address = 147 R/W (0x93)
CHIP_VER_REV1 (BLOCK0): Silicon Revision 1 = True R/W (0b1)
CHIP_VER_REV2 (BLOCK0): Silicon Revision 2 = True R/W (0b1)
WAFER_VERSION_MINOR (BLOCK0): WAFER VERSION MINOR = 0 R/W (0b00)
CHIP_PACKAGE (BLOCK0): Chip package identifier = 1 R/W (0b001)
CHIP_PACKAGE_4BIT (BLOCK0): Chip package identifier #4bit = 0 R/W (0b0)
MAC_VERSION (BLOCK3): Version of the MAC field = 0 R/W (0x00)
WAFER_VERSION_MAJOR (BLOCK0): calc WAFER VERSION MAJOR from CHIP_VER_REV1 and CH = 3 R/W (0b011)
IP_VER_REV2 and apb_ctl_date (read only)
PKG_VERSION (BLOCK0): calc Chip package = CHIP_PACKAGE_4BIT << 3 + CHIP_ = 1 R/W (0x1)
PACKAGE (read only)
Security fuses:
FLASH_CRYPT_CNT (BLOCK0): Flash encryption mode counter = 1 R/W (0b0000001)
UART_DOWNLOAD_DIS (BLOCK0): Disable UART download mode (ESP32 rev3 only) = False R/W (0b0)
FLASH_CRYPT_CONFIG (BLOCK0): Flash encryption config (key tweak bits) = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE (BLOCK0): Disable ROM BASIC interpreter fallback = True R/W (0b1)
ABS_DONE_0 (BLOCK0): Secure boot V1 is enabled for bootloader image = False R/W (0b0)
ABS_DONE_1 (BLOCK0): Secure boot V2 is enabled for bootloader image = False R/W (0b0)
JTAG_DISABLE (BLOCK0): Disable JTAG = True R/W (0b1)
DISABLE_DL_ENCRYPT (BLOCK0): Disable flash encryption in UART bootloader = False R/W (0b0)
DISABLE_DL_DECRYPT (BLOCK0): Disable flash decryption in UART bootloader = True R/W (0b1)
DISABLE_DL_CACHE (BLOCK0): Disable flash cache in UART bootloader = True R/W (0b1)
BLOCK1 (BLOCK1): Flash encryption key
BLOCK2 (BLOCK2): Secure boot key
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK3 (BLOCK3): Variable Block 3
Flash voltage (VDD_SDIO) determined by GPIO12 on reset
谢谢!
