ESP32 app_main() loop
JJ8428
Postby JJ8428 » Fri Aug 04, 2023 5:10 am
This is some code I wrote for my ESP32S2. I am a bit slow since I am learning C and the ESP-IDF framework at the same time.
The purpose of this code is supposed to a Wifi FTM Responder. I plan on writing code for the Wifi FTM Initiator that checks the distance every quarter second in the future.
In my app_main() function, I am calling wifi_ap() near the end. Then I have a while loop with vTaskDelay() command for 1 full second. I know that the vTaskDelay() code is halting the code for a full second, but my question is does the SoftAP (this is created/registered in the wifi_ap() function) continue to exist during that halt? If so, can some please suggest a different way to loop the app_main() near the end where the SoftAP continues to exist?
I have also tried just doing while(1); (There is no vTaskDelay), but the "Task Watchdog Error" appears, so I think I need the vTaskDelay()?
Code: Untitled.c Select all
#include <stdio.h>
#include <string.h>
#include <inttypes.h>
#include "nvs_flash.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_err.h"
#include "esp_wifi.h"
#include "freertos/task.h"
#include "sdkconfig.h"
// Define Wifi Characteristics
const char* SSID = "JJ8428";
const char* PWD = "Renualt88";
wifi_config_t g_ap_config = {
.ap.max_connection = 1,
.ap.authmode = WIFI_AUTH_WPA2_PSK,
.ap.ftm_responder = true
// Object to deliver Wifi events
static EventGroupHandle_t s_wifi_event_group;
static const char *TAG_AP = "ftm_ap";
static void event_handler(void *arg, esp_event_base_t event_base,
int32_t event_id, void *event_data)
if (event_id == WIFI_EVENT_AP_START) {
ESP_LOGI(TAG_AP, "SoftAP started with FTM Responder support");
} else if (event_id == WIFI_EVENT_AP_STOP) {
ESP_LOGI(TAG_AP, "SoftAP stopped"); // White LED off: Wifi SoftAP deactivated
static int wifi_ap()
strlcpy((char*) g_ap_config.ap.ssid, SSID, strlen(SSID));
strlcpy((char*) g_ap_config.ap.password, PWD, strlen(PWD));
// SoftAP Configurations
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &g_ap_config));
esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20); // SoftAP Bandwidth: 20 MHz
// Log an informational message indicating the start of the SoftAP configuration.
ESP_LOGI(TAG_AP, "SoftAP with the following credentials: SSID - %s, Password - %s",
SSID, PWD
return true;
void app_main(void)
ESP_ERROR_CHECK(ret);
ESP_ERROR_CHECK(esp_event_loop_create_default()); // Can be expanded on to handle gain/loss of client
esp_event_handler_instance_t instance_any_id;
ESP_ERROR_CHECK(esp_event_handler_instance_register(
WIFI_EVENT,
ESP_EVENT_ANY_ID,
&event_handler,
NULL,
&instance_any_id
ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_NULL));
ESP_ERROR_CHECK(esp_wifi_start());
// Start the SoftAP and keep the code looping to host the SoftAP forever
// THIS IS WHERE I AM CONFUSED
if (!wifi_ap()) {
ESP_LOGE(TAG_AP, "Failed to start SoftAP!");
while (true) {
vTaskDelay(1000 / portTICK_PERIOD_MS); // DOES THE SOFTAP CONTINUE TO EXIST IN A FTM FRIENDLY STATE? IS THE WIFI PAUSED?
[/code]
MicroController
Re: ESP32 app_main() loop
Postby MicroController » Fri Aug 04, 2023 8:50 am
Yes, the WiFi/AP will remain active once it's started. The handling of WiFi happens concurrently to your application's tasks. The driver will create a new task automatically to handle WiFi which runs concurrently ("in the background") to your application's task(s) and communicates with your code via the event loop (which runs in its own task again).
You can do other things in your main task, or even exit it, without affecting WiFi.
As you noticed, you should just make sure that your main task (or any other task) does not keep using 100% of the CPU, as an empty while(true) { } loop will do, else you'll raise the anger of the watchdog.
JJ8428
Postby JJ8428 » Sat Aug 05, 2023 2:46 pm
Thank you for your input.
johnatanjmn
Postby johnatanjmn » Mon Jul 21, 2025 7:25 pm
Sorry to bump such an old topic up but I find the question still relevant.
Isn't there a proper way to tell the ESP32 to just terminate all execution and quit (until power cycle).
I using an ISR to detect some sensor reading: https://lastminuteengineers.com/handlin ... -tutorial/
As soon as this goes high I want the same result for the code to completely terminate.
This works fine with the Arduino if you just say exit(), not with the ESPs, if I call exit it will just keep rebooting.
johnatanjmn
Postby johnatanjmn » Fri Aug 01, 2025 10:15 pm
So that's it? There is no real solution to terminate the chip all code execution and shut down? :x
Obviously it's great at crashing, segfaulting and rebooting then why can't we have a shut down function :D
nopnop2002
Contact:
Postby nopnop2002 » Fri Aug 01, 2025 10:42 pm
There are only limited things that can be done within an ISR function.
For example, set a global variable to True.
void IRAM_ATTR isr() {
  shutdown = true;
Then, within the task, check the global variable and execute vTaskDelete().
if(shutdown) vTaskDelete(null);
https://www.freertos.org/Documentation/ ... TaskDelete
FreeRTOS does not have the concept of shutdown.
When there is nothing to do, only the idle task runs.
Stop all user tasks.
markkuk
Postby markkuk » Sat Aug 02, 2025 7:37 am
Put the chip in deep sleep with all wakeup sources disabled.
Users browsing this forum: Baidu [Spider] and 3 guests
