ESPNOW messages being dropped
koshin
Postby koshin » Sun Aug 06, 2023 11:48 am
I have 13 ESP32-C3 devices in a room sending messages at a rate of up to 10 messages per device per second. All the devices are within wifi range of each other, and all the messages are sent as single-packet ESP-NOW transmissions. Each message is sent on the same wifi channel, and all messages are broadcast to everyone. There are no other wifi devices in the vicinity.
It seems, though I have not confirmed, that a significant fraction of ESPNOW messages are being dropped (20%?). How likely is it that I would see significant packet drop on the ESPNOW protocol at ~130 messages per second?
Is it more likely to be a transmission queuing problem on the sending side, or a receive queuing problem on the receiving side, or interference between simultaneous transmissions?
(I am coding in C using ESP-IDF 5.1. I am working with the ESP32-C3-DevKit2 board.)
Penguin_Helper
Re: ESPNOW messages being dropped
Postby Penguin_Helper » Wed Aug 09, 2023 3:37 am
Hi, the most likely cause of your packet loss is the degree of channel congestion. You may consider assigning different channels to your devices.
We tested the round-trip delay time and packet loss rate during the testing of both unicast and broadcast packet transmission by the subdevices. You can use this result as a reference.
bhuvanchandradv
Postby bhuvanchandradv » Wed Feb 19, 2025 4:59 am
Sorry for hijacking the thread.
Based on our tests, the round-trip latency in the broadcast looks okay. However, in the pictures, I see an increase in round-trip latency as the range increases. I would like to know if there is any relationship between latency and range in ESP-NOW devices.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bytespider, ChatGPT-User, Qwantbot and 5 guests
