Setting a RTC_GPIO in esp_wake_deep_sleep()
Posted: Wed Aug 09, 2023 7:00 am
by NRollo
On a ESP32-D0WD module I am trying to set RTC_GPIO8 (GPIO33) in the esp_wake_deep_sleep() function using the esp-idf framework. This obviously means some REG_WRITE() and REG_READ() register "joggling".
So far I have come up with this (which apparently is not enough):
Code: Untitled.c Select all
    // Enable GPIO output
REG_WRITE(RTC_GPIO_ENABLE_W1TS_REG, REG_READ(RTC_GPIO_ENABLE_REG) | BIT(RTC_GPIO_ENABLE_W1TS_S + 8));
// Set the GPIO output bit high
REG_WRITE(RTC_GPIO_OUT_W1TS_REG, REG_READ(RTC_GPIO_OUT_REG) | BIT(RTC_GPIO_OUT_DATA_W1TS_S + 8));
Can anyone give me at hint on what ESP32 registers to use right after deep sleep wakeup, in order to set GPIO33 (RTC_GPIO8) to high?
Thanks!
Re: Setting a RTC_GPIO in esp_wake_deep_sleep()
Posted: Wed Aug 09, 2023 8:56 am
by NRollo
I found a solution, this will do the trick:
void RTC_IRAM_ATTR esp_wake_deep_sleep(void) {
// Output - set RTC mux
SET_PERI_REG_MASK(RTC_IO_XTAL_32K_PAD_REG, BIT(RTC_IO_X32N_MUX_SEL_S));
// Output - clear the HOLD bit
CLEAR_PERI_REG_MASK(RTC_IO_XTAL_32K_PAD_REG, BIT(RTC_IO_X32N_HOLD_S));
// Output - enable GPIO output
REG_WRITE(RTC_GPIO_ENABLE_W1TS_REG, BIT(RTC_GPIO_ENABLE_W1TS_S + GPIO_NUM_8));
// Ouput - set the GPIO output high
REG_WRITE(RTC_GPIO_OUT_W1TS_REG, BIT(RTC_GPIO_OUT_DATA_W1TS_S + GPIO_NUM_8));
ets_delay_us(450000);
// Ouput - clear the GPIO output
REG_WRITE(RTC_GPIO_OUT_W1TC_REG, BIT(RTC_GPIO_OUT_DATA_W1TS_S + GPIO_NUM_8));
