ESP32-S3-MINI-1 wouldn't start
Posted: Wed Aug 09, 2023 2:28 pm
Dear All,
I am fairly experienced in the old ESP32 chips and now I am starting to use the newer ESP32-S3 chips, and in my first project an ESP32-S3-MINI-1. Read all the documentation and datasheet, but I can't get it to start.
I am using The Arduino framework in Visual Studio Code + Platformio.
Here is my platformio.ini:
This is the code I am trying:
It compiles and uploads just fine, but when starting to run I get the following in the serial terminal:
Any idea what's going wrong?
[env:esp32-s3-devkitc-1]
platform = espressif32 @ 5.3.0
board = esp32-s3-devkitc-1
framework = arduino
monitor_speed = 115200
monitor_port = COM3
monitor_filters =
colorize
esp32_exception_decoder
upload_port = COM3
upload_speed = 921600
#include <Arduino.h>
#define LED_PIN GPIO_NUM_5
void setup() {
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW);
Serial.begin(115200);
Serial.println("Start blinky");
void loop() {
Serial.println("LED ON");
delay(200);
Serial.println("LED OFF");
digitalWrite(LED_PIN, HIGH);
delay(200);
}Code: Select all
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x28 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbec
load:0x403cc700,len:0x2920
entry 0x403c98d8
