ESP32-PICO unknown Chip ID
andriy
Postby andriy » Fri Nov 03, 2017 6:53 pm
I made my own board using ESP32-PICO-D4.
When flashing it, I found something like this:
Flashing binaries to serial port /dev/cu.SLAB_USBtoUART (app at offset 0x10000)...
esptool.py v2.1
Connecting........_
Chip is unknown ESP32 (revision 0)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
As we can see "Chip is unknown ESP32 (revision 0)" ---> is it normal?
If not, what's the possible cause?
Thanks!
WiFive
Re: ESP32-PICO unknown Chip ID
Postby WiFive » Fri Nov 03, 2017 7:31 pm
Yes, esptool just doesn't have it listed
andriy
Postby andriy » Sat Nov 04, 2017 1:56 am
Thanks! Good to go then.
Users browsing this forum: Applebot, PerplexityBot, Semrush [Bot] and 1 guest
