Sorry if I'm being hasty but I didn't see anywhere talking about deadline for response. I asked for the PID but I didn't get an answer, could someone help me?
Here is my request link: https://github.com/frotaitalo/usb-pids/ ... c2518e6db6
I requested the PID allocated in the ESP's VID but got no response.
frotaitalos
Re: I requested the PID allocated in the ESP's VID but got no response.
You did not request a PID here; you cloned the repository and made a change to it, which is part of the process, but this is still all in your own repository. To actually request the PID, you need to make a pull request to merge the change you made back into the Espressif repository.
Edit: It's a bit more complicated, you seem to have attached your commit to an existing, closed pull request? No clue how you'd do that tbh. For reference, this documents how to make a proper pull request.
frotaitalos
I believe that now I made the pull request correctly, could you check for me?You did not request a PID here; you cloned the repository and made a change to it, which is part of the process, but this is still all in your own repository. To actually request the PID, you need to make a pull request to merge the change you made back into the Espressif repository.
Users browsing this forum: Applebot, Qwantbot and 1 guest
