Reset MCU while opening serial port
ogedik
Postby ogedik » Tue Sep 12, 2023 3:41 pm
I am working on a circuit based on AiThinker ESP32-C3-13/13U-Kit and communicating ESP32 kit with my computer through GPIO18 and GPIO19. The problem is when I open COM port on my .Net application, MCU resets and boot itself. So I made a research and found out that RTS pin is connected to ESP32-C3 EN pin so that when I open port by my .Net appliction on my computer to ESP32 kit through COM port, MCU get reset signal and reboot.
To solve this problem I set properties as below;
                    _serialPort.PortName = port;
                    _serialPort.BaudRate = 115200;
                    _serialPort.DtrEnable = true;
                    _serialPort.RtsEnable = false;
                    // Set the read/write timeouts
                    _serialPort.ReadTimeout = 1000;
                    _serialPort.WriteTimeout = 1000;
                   try
                        _serialPort.Open();
                        message = _serialPort.ReadLine();
                        if (message == "HELLO\r")
                            // device connected
                            _serialPort.Close();
                            statusLabel.Text = "Cihaz bulundu";
                            return (port);
Even though I disable RTS, MCU still resets and boot itself. I tried all combinations for DtrEnable and RtsEnable properties. But result didn't change.
Anybody can help me to solve this issue?
Thank you
Orkun Gedik
ogedik
Re: Reset MCU while opening serial port
Postby ogedik » Tue Sep 12, 2023 6:21 pm
Hi Orkun,
You should set handshake after set property RtsEnable = true. Use properties as below;
                _serialPort.RtsEnable = true;
                _serialPort.Handshake = System.IO.Ports.Handshake.RequestToSend;
ogedik
Postby ogedik » Tue Sep 12, 2023 8:33 pm
Hi Orkun,
It worked as you suggested. Thank you
Users browsing this forum: ChatGPT-User and 3 guests
