I don't succeed to launch GDB but i succeed to launch OPENOCD (ESP-IDF and ESP32-C3 with ESP-PROG and VSCODE and Win10)
Posted: Thu Sep 14, 2023 10:34 am
Good Morning,
I'am trying to make an ESP32-C3 based project. (ESP-IDF project and VSCODE on Win10)
I would like to use the external debugger ESP-PROG
I am stuck on launching the debugger with VSCODE
Here below my launch.json
here below my tasks.json
OPENOCD launch message is OK
Could you help me please
Best regards
Jose Miguel
"version": "0.2.0",
"configurations": [
// "preLaunchTask": "OpenOCD: Start openOCD",
// "type": "espidf",
// "name": "Launch",
// "request": "launch",
// "debugPort": 43474,
// "logLevel": 2,
// "mode": "manual",
// "verifyAppBinBeforeDebug": false,
// "tmoScaleFactor": 1,
// "initGdbCommands": [
// "target extended-remote :3333",
// "symbol-file ${workspaceFolder}/build/fast-scan.elf",
// "mon reset halt",
// "flushregs",
// "thb app_main"
// "env": {
// "CUSTOM_ENV_VAR": "SOME_VALUE"
"name": "Launch",
"type": "cppdbg",
"cwd": "${workspaceFolder}/build",
"program": "${workspaceFolder}/build/fast-scan.elf",
"miDebuggerPath": "C:/Users/josem/.espressif/tools/riscv32-esp-elf-gdb/11.2_20220823/riscv32-esp-elf-gdb/bin/riscv32-esp-elf-gdb-3.9.exe",
//"MIMode": "gdb",
//"windows": {"${workspaceFolder}\\build\\${command:espIdf.getProjectName}.elf"},
"environment": [{ "name": "PATH", "value": "${config:idf.customExtraPaths}" }],
"setupCommands": [
{"text": "target remote 127.0.0.1:3333"},
{"text" : "set remote hardware-watchpoint-limit 2"},
{"text": "mon reset halt"},
{"text": "thb app_main"},
{"text": "flushregs"}
"externalConsole": false,
"logging": {
"engineLogging": true
}Code: Select all
"version": "2.0.0",
"tasks": [
"label": "Build - Build project",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py build",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py build",
"options": {
"env": {
"PATH": "${env:PATH};${config:idf.customExtraPaths}"
"options": {
"env": {
"PATH": "${env:PATH}:${config:idf.customExtraPaths}"
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"${workspaceFolder}"
"pattern": {
"regexp": "^\\.\\.(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"fileLocation": "absolute",
"pattern": {
"regexp": "^[^\\.](.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"group": {
"kind": "build",
"isDefault": true
"label": "Set ESP-IDF Target",
"type": "shell",
"command": "${command:espIdf.setTarget}",
"problemMatcher": {
"owner": "cpp",
"pattern": {
"regexp": "^(.*):(//d+):(//d+)://s+(warning|error)://s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Clean - Clean the project",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py fullclean",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py fullclean",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Flash - Flash the device",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} -b ${config:idf.flashBaudRate} flash",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py flash -p ${config:idf.portWin} -b ${config:idf.flashBaudRate}",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Monitor: Start the monitor",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} monitor",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py -p ${config:idf.portWin} monitor",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"dependsOn": "Flash - Flash the device"
"label": "OpenOCD: Start openOCD",
"type": "shell",
"presentation": {
"echo": true,
"reveal": "never",
"focus": false,
"panel": "new"
//"command": "openocd -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
//"command": "openocd -s ../share/openocd/scripts/ ${command:espIdf.getOpenOcdConfigs} -c ftdi tdo_sample_edge falling",
"command": "openocd -s ../share/openocd/scripts/ ${command:espIdf.getOpenOcdConfigs}",
"windows": {
//"command": "openocd.exe -s ../share/openocd/scripts/ ${command:espIdf.getOpenOcdConfigs} -c ftdi tdo_sample_edge falling",
"command": "openocd.exe -s ../share/openocd/scripts/ ${command:espIdf.getOpenOcdConfigs}",
//"command": "openocd.exe -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": {
"owner": "cpp",
"pattern": {
"regexp": "^(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "adapter",
"type": "shell",
"command": "${config:idf.pythonBinPath}",
"isBackground": true,
"options": {
"env": {
"PATH": "${env:PATH}:${config:idf.customExtraPaths}",
"PYTHONPATH": "${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter"
"problemMatcher": {
"background": {
"beginsPattern": "\bDEBUG_ADAPTER_STARTED\b",
"endsPattern": "DEBUG_ADAPTER_READY2CONNECT",
"activeOnStart": true
"pattern": {
"regexp": "(\\d+)-(\\d+)-(\\d+)\\s(\\d+):(\\d+):(\\d+),(\\d+)\\s-(.+)\\s(ERROR)",
"file": 8,
"line": 2,
"column": 3,
"severity": 4,
"message": 9
"args": [
"${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter_main.py",
"-e",
"${workspaceFolder}/build/${command:espIdf.getProjectName}.elf",
"-s",
"${command:espIdf.getOpenOcdScriptValue}",
"-ip",
"localhost",
"-dn",
"${config:idf.adapterTargetName}",
"-om",
"connect_to_instance"
"windows": {
"command": "${config:idf.pythonBinPathWin}",
"options": {
"env": {
"PATH": "${env:PATH};${config:idf.customExtraPaths}",
* Executing task: openocd.exe -s ../share/openocd/scripts/ -f board/esp32c3-ftdi.cfg
Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:48)
Licensed under GNU GPL v2
For bug reports, read
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Info : datacount=2 progbufsize=16
Info : Examined RISC-V core; found 1 harts
Info : hart 0: XLEN=32, misa=0x40101104
Info : starting gdb server for esp32c3 on 3333
Warn : Haven't made progress in mpsse_flush() for 330995ms.
Warn : Haven't made progress in mpsse_flush() for 331002ms.
Best regards
Jose Miguel
