ESP32 + OV7670 camera: need assistance
Posted: Wed Sep 20, 2023 5:06 pm
I'm struggling with OV7670 camera and still can't get proper images out of it...
I want to get a 256x256 monochrome pixel region. Camera operates in YUV422 mode so I'm aimed at a higher 8-bits part of the 16-bit output. With that said, I'm having the following:
- all pads configured as pulled-up inputs; VSYNC inverted, interrupt attached.
- clocking @ 20MHz or 40MHz via LEDC
- D0...D7 MUXed to appropriate I2S signalling
- camera module is missing HREF pad so I'm using HSYNC instead
- windowing consigured as per datasheet (HSTART, VSTART, HSTOP, VSTOP, HREF)
- test grayscale mode activated
- I2S has the following capturing config:
-- I2S0.conf.rx_right_first = 0;
-- I2S0.conf.rx_msb_right = 0;
-- I2S0.fifo_conf.rx_fifo_mod = 1;
Hence I expect to get the byte flow: CAMERA = s1, s2, s3, s4, ... FIFO = 00 s1 00 s2, 00 s3 00 s4, ... (shown in many source files on github).
FIFO/DMA configured to fill the temporary junkBuffer with 4096 words (16834 bytes). Later on I pick up the luma bytes from there.
RESULTS:
(a) the junkBuffer reads this (the first 32 bytes are shown per frame):
The "XX 00 YY 00" pattern differs from expected "00 XX 00 YY"
(2) I ran 4 different scenarios and picked up every N-th byte (0...3) from the junkBuffer and got the following images:
Once (on a very rare occasion) I happened to get a more or less structured pattern:
(3) The picures above were generated by the camera with a terrible 20cm wiring. In hope to cut off the possible noise I reassembled the design replacing signal wires with a thick short soldered pins wrapped in isolator. VCC/GND/SDA/SCL/RESET and PWDN are left untouched.
Such a modification did not yield any positive result however
RESULTS:
54 00 54 00 86 00 86 00 54 00 54 00 86 00 86 00 54 00 54 00 86 00 86 00 54 00 54 00 86 00 86 00
A5 00 A5 00 9D 00 9D 00 A5 00 A5 00 9D 00 9D 00 A5 00 A5 00 9D 00 9D 00 A5 00 A5 00 9D 00 9D 00
B6 00 B6 00 B2 00 B2 00 B6 00 B6 00 B2 00 B2 00 B6 00 B6 00 B2 00 B2 00 B6 00 B6 00 B2 00 B2 00
A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00 A0 00
86 00 86 00 54 00 54 00 86 00 86 00 54 00 54 00 86 00 86 00 54 00 54 00 86 00 86 00 52 00 52 00(2) I ran 4 different scenarios and picked up every N-th byte (0...3) from the junkBuffer and got the following images:
