[VSCODE+ESP32H2] OpenOCD do not see correct script?
Posted: Tue Oct 03, 2023 10:20 pm
by parf.nick
Hello.
I try to use VS Code with Espressif IDF plugin for ESP32-H2-DevKitM1.
When use launch(debug) settings(file settings.json) like this:
Code: Untitled.js Select all
"C_Cpp.intelliSenseEngine": "Tag Parser",
"idf.adapterTargetName": "esp32h2",
"cmake.configureOnOpen": false,
"idf.openOcdConfigs": [
"board/esp32h2-builtin.cfg"
openocd give me error, like this:
Code: Untitled.css Select all
[OpenOCD]
❌ Error: unable to open ftdi de ice with description '*', serial '*' at bus location '*'
C:\Espressif\tools\openocd-esp32\v0.12.0-esp32-20230419/openocd-esp32/share/openocd/scripts/target/esp_common.cfg:4: Error:
at file "C:\Espressif\tools\openocd-esp32\v0.12.0-esp32-20230419/openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 4
I have same error, when launch openocd from command line, like this (pass ftdi-script):
openocd.exe -f board\esp32h2-ftdi.cfg
As i think, plugin do not pass board/esp32h2-builtin.cfg builtin script correctly to open ocd.
What's wrong?
Thank you.
Re: [VSCODE+ESP32H2] OpenOCD do not see correct script?
Posted: Wed Oct 04, 2023 7:19 pm
by parf.nick
Found other feature:
If idf.openOcdConfigs config field do not contain reference to interface script, openocd automatically use wrong VIN/PID and can not found the device.
With VS Code config like this:
"idf.adapterTargetName": "custom",
"idf.customAdapterTargetName": "esp32h2",
"idf.flashType": "JTAG",
"idf.portWin": "COM7",
"idf.openOcdDebugLevel": 4,
"idf.openOcdLaunchArgs": ["-l openocd_log.txt"],
OpenOCD output is:
Debug: 23 12 command.c:152 script_debug(): command - espusbjtag vid_pid 0x303a 0x1002
Info : 24 12 esp_usb_jtag.c:894 esp_usb_jtag_vid_pid(): esp_usb_jtag: VID set to 0x303a and PID to 0x1002
Debug: 25 12 command.c:152 script_debug(): command - espusbjtag caps_descriptor 0x030A
Error: 119 1463 esp_usb_jtag.c:646 esp_usb_jtag_init(): esp_usb_jtag: could not find or open device!
But, for Espressif IDE with same script file (board/esp32h2-builtin.cfg) for OpenOCD, output is:
Info : only one transport option; autoselecting 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Info : esp_usb_jtag: serial (48:31:B7:C0:2A:E1)
Info : esp_usb_jtag: Device found. Base speed 24000KHz, div range 1 to 255
To find device correctly, type interface script explicitely:
"[b]interface/esp_usb_jtag.cfg[/b]",
PS: Despite device found, debug session can't start correctly. Dont know why, this is next episodes;)
Posted: Thu Oct 05, 2023 1:19 pm
by radurentea
Can you run the "ESP-IDF: Doctor Command" (from Command Palette) and provide me with the output? It will be copied to the clip board
Posted: Fri Oct 06, 2023 4:22 pm
by parf.nick
Hi.
report.txt
(11.26 KiB) Downloaded 255 times
Posted: Fri Oct 06, 2023 4:29 pm
by parf.nick
This is openocd log file, when device detected, but debug session can't start:
openocd_log.zip
(4.85 MiB) Downloaded 349 times
