Reyax RYS8830 GPS/GNSS Receiver Module EVB not working
Posted: Wed Oct 11, 2023 3:06 am
by joaquinegn
I have been working on a little project and I am stucked on this since some weeks ago, i am very newbie on it, could you help me out? I want to get the gps data using RYS8830 EVB but I am getting "No GPS detected: check wiring." always, both devices connected to usb laptop. Using the software I could see the location very accurate.
Devices list:
1) ESP32 DEV KIT v1
2) Reyax RYS8830 GPS/GNSS Receiver Module EVB
3) 8-channel Bi-directional Logic Level Converter - TXB0108 (3.3v - 1.8v)
My wired is the following (jumper activaded on UART protocol on GPS EVB):
Based on the documentarion I have used the RX,TX,Ground and 1.8V output as following:
EVB RX -> ESP32 TX
EVB TX -> ESP32 RX
The code is:
#include <TinyGPSPlus.h>
const int rx = 16;
const int tx = 17;
static const uint32_t serialBaud = 115200;
// The TinyGPSPlus object
TinyGPSPlus gps;
String incoming = "";
void setup()
  Serial.begin(serialBaud);
  Serial2.begin(serialBaud, SERIAL_8N1, rx, tx);
  delay(1000);
  writeDataToGPS("@GSTP");
  delay(100);
  writeDataToGPS("@GNS 47");
  delay(100);
  writeDataToGPS("@GSR");
  delay(100);
  Serial.println("SETUP");
void loop()
  // This sketch displays information every time a new sentence is correctly encoded.
  while (Serial2.available() > 0) {
    if (Serial.println(Serial2.read())) {
      Serial.println(F("GPS detected."));
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void writeDataToGPS(String data)
  String content = "";
  content = data + "\r\n";
  char* bufc = (char*) malloc(sizeof(char) * content.length() + 1);
  content.toCharArray(bufc, content.length() + 1);
  Serial2.write(bufc);
  free(bufc);
void displayInfo()
  if (gps.location.isValid())
    char data[20];
    sprintf(data, "%lf,%lf|", gps.location.lat(), gps.location.lng());
    Serial.println(gps.location.lat());
    Serial.write(data);
    Serial.flush();
    delay(100);
Usingthe vendor software:
Captura de pantalla 2023-10-10 235502.png (7.05 KiB) Viewed 3659 times
Thank you in advanced!!
