How to maximize ESP-NOW range?
Moskus
Postby Moskus » Wed Nov 01, 2023 10:06 am
I'm sending data every second from many ESP32s ("nodes") to a receiver ESP32 ("station"), and I'm trying to get the absolute maximum transmit length possible. Many sources on guides and Youtube claims to achieve range in the hundres of meters using "standard development boards", but I'm not quite there yet.
I get around 70 m range when the receiver is placed indoors but very close to a large window, and the transmitter is outside. It's not bad, but not what I need.
Here's what I'm doing initializing ESP-NOW on the transmitters ("nodes"):
  // Configuring ESP-NOW
  ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
  ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
  ESP_ERROR_CHECK(esp_wifi_start());
  // WiFi.mode(WIFI_STA);
  // Set Long Range Mode
  ESP_ERROR_CHECK(esp_wifi_set_protocol(WIFI_IF_STA, WIFI_PROTOCOL_LR));
  //Set the lowest espnow phy rate to maximum range
  ESP_ERROR_CHECK(esp_wifi_config_espnow_rate(WIFI_IF_STA, WIFI_PHY_RATE_LORA_250K));
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK)
    Serial.println("Error initializing ESP-NOW");
    return;
  // Set transmission power, max 84.
  ESP_ERROR_CHECK(esp_wifi_set_max_tx_power(84));
  //Register callback to verify if data was sent successfully
  esp_now_register_send_cb(OnDataSent);
And the receiver:
    // Set custom MAC
    esp_wifi_set_mac(WIFI_IF_STA, localCustomMac);
    // Set the Long Range mode
    // Initialize
        return;
    // Register for recv CB to  get recv packet info
    esp_now_register_recv_cb(OnDataRecv);
Am I missing something?
Is there anything else I can do?
cruvus
Re: How to maximize ESP-NOW range?
Postby cruvus » Wed Nov 01, 2023 1:46 pm
What is your power saving setting? In some early experiments I had to set
esp_wifi_set_ps(WIFI_PS_NONE);
else I did not receive anything.
Moskus
Postby Moskus » Mon Nov 06, 2023 11:58 am
Yes, I've set that too now. I will have to do some field tests.
g.gregory8
Postby g.gregory8 » Sat Mar 30, 2024 9:42 am
Hi did you get a solution to increasing range by decreasing bandwidth or any other functions?
Gijsbertud79
Postby Gijsbertud79 » Sun Nov 03, 2024 6:49 pm
I have the same problem. There is not much information about the long range mode. Could please someone help?
I have placed a solar pannel on my garage its 300 meters away from my home. I'd like to monitor the battery from my home.
Users browsing this forum: Google [Bot], PerplexityBot and 6 guests
