Hello all,
Thank you for reading this post. What im struggling with is the not so much docs/examples to find of a ESP32-WROOM-32UE-N16 in combination of a SD slot and a Lan8720. This board is meant to be remotely placed in a Escaperoom and using MQTT for the communication and no WiFi therefor the Lan connection. The SD slot is used for loging/firmware update/configuration files.
Attached is the schematic if you would have the time would and could you give some tips on where to proceed?
The schematic is not complete yet. I am adding a CH340 for programming and going to add 4 relays and 6 inputs via optocouplers and transistors etc.
Thank you in advance
ESp32 - Lan8720 schematic review
remco.halman
- Schematic_ESP-LAN-SD_2023-11-04.pdf
- (162.27 KiB) Downloaded 415 times
Users browsing this forum: YisouSpider and 2 guests
