SdFat is an amazing open-source library for Arduino and ESP32 projects to use SD and Nand storage. It's been around since 2009. @greiman does an amazing job, even if SdFat is impossible to maintain. This is my contribution, a recipe for fellow ESP32 enthusiasts needing to format an SD for Fat16 over SPI. I wrote it for my [Reflections](https://github.com/frankcohen/ReflectionsOS) open-source project. It uses an ESP32-S3 and Nand/SD.
### Install SdFat
I used SdFat version 2.2.2. Open the Library Manager in Arduino IDE 2.2.1.
### SdFatConfig.h Configuration
Make these changes to:
arduino/libraries/SdFat/src/SdFatConfig.h
Find this definition, change its value to 3
#define SPI_DRIVER_SELECT 3
### Schematic
<img src="https://raw.githubusercontent.com/frank ... -SdFat.jpg" alt="SD attaches to ESP32 over SPI" width="100%"/>
### Sketch
Refer to the code
[https://github.com/frankcohen/Reflectio ... Formatting](https://github.com/frankcohen/Reflectio ... Formatting)
GPIO 12 is the chip-select for a TFT video display on the same SPI bus as the SD/Nand. This tells SdFat to disable it.
const int8_t DISABLE_CS_PIN = 12;
GPIO 15 is the chip-select for the SD/Nand.
#define SD_CS_PIN 15
ESP32 allows any GPIO pins to be an SPI bus. See [Andreas Speiss video and spreadsheet](https://www.youtube.com/watch?v=LY-1DHTxRAk) to know the limitations. Reflection's board uses 35, 36, 37 for SPI between the SD/Nand and Display.
#define SPI_MOSI 35
#define SPI_MISO 37
#define SPI_SCK 36
Additional GPIO pins used by the Reflections board display.
#define Display_SPI_DC 5
#define Display_SPI_CS 12
#define Display_SPI_RST 0
#define Display_SPI_BK 6
Custom SPI connection class, begin method starts the SPI bus using the GPIO pins.
class MySpiClass : public SdSpiBaseClass {
SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI, -1);
SdFat sets SPI bus speed with the SD_SCK_MHZ macro. 50 works for my ESP32-S3-Mini-N1. I have found no clear method of determining the speed for a given board and SD/Nand component. Try lesser values. For example, 30, 20, 10.
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SD_SCK_MHZ(50), &mySpi)
Sets the GPIO pins that support the SD/Nand and the display. These are specific to the [Reflections](https://github.com/frankcohen/ReflectionsOS) board and you may change them for your board.
pinMode(SD_CS_PIN, OUTPUT );
digitalWrite(SD_CS_PIN, LOW);
pinMode(Display_SPI_CS, OUTPUT);
digitalWrite(Display_SPI_CS, LOW);
pinMode(Display_SPI_DC, OUTPUT);
digitalWrite(Display_SPI_DC, HIGH);
pinMode(Display_SPI_RST, OUTPUT);
digitalWrite(Display_SPI_RST, HIGH);
pinMode(Display_SPI_BK, OUTPUT);
digitalWrite(Display_SPI_BK, LOW);
## Arduino IDE 2.x settings
Using Arduino IDE 2.x, use Tools menu options:
Board: ESP32S3 Dev Module
USB CDC On Boot: Enabled
Core Debug Level: Error
USB DFU On Boot: Disabled
Erase All Flash Before Sketch Upload: Disabled
Events Run On: Core 1
Flash Mode: QIO 80 Mhz
Flash Size: 8 MB (64MB)
JTAG Adapter: Integrated USB JTAG
Arduino Runs On: Core 1
USB Firmware MSC On Boot: Disabled
Partition Scheme: Defaults 4MB with Spiffs (1.2 MB APP/1.5MB SPIFFS)
PSRAM: Disabled
Upload Mode: UART0/Hardware CDC
Upload Speed 921600
USB Mode: Hardware CDC and JTAG
## JCUSB, USB, JTAG Debugging, Connection
Connect your computer to an ESP32-S3 using a technique I call [JCUSB](https://github.com/frankcohen/Reflectio ... bugging.md). JCUSB is short for S3 + USB + CDC + OpenOCD + Arduino IDE. Only ESP32-S3 and its successors support JCUSB - it won't work on ESP32 and ESP32-S2. JCUSB uses a custom USB cable to connect an ESP32 to a Windows or MacOS computer. [Details here](https://github.com/frankcohen/Reflectio ... bugging.md)
# Compile and Run
Once you customize the above values, compile and upload the code. Then open the Serial Monitor, set the connection speeed to 115200, follow the on-screen instructions.
Here is an example. I ran this on my MacOS laptop using Arduino IDE 2.2.1.
SdFat version: 2.2.2
Disabling SPI device on pin 12
Assuming the SD chip select pin is: 15
Edit SD_CS_PIN to change the SD chip select pin.
Done
type any character to start
## What May Go Wrong
SdFat works with a lot of hardware and SD cards, and it is possible it will not work with yours.
- SPI bus speed. SdFat sets SPI bus speed with the SD_SCK_MHZ macro. 50 works for my ESP32-S3-Mini-N1. I have found no clear method of determining the speed for a given board and SD/Nand component. Try lesser values. For example, 30, 20, 10.
- SD card won't format. Usually because it is broken. Or maybe partially zapped from static electricity. Or it is a low quality SD card that works inconsistently.
- Conflicts with the board definitions. Check the pin use on your board.
In the event something goes wrong, SdFat's creator/maintainer does an amazing job at interacting with his community. I recommend you search the [issues](https://github.com/greiman/SdFat/issues), and if you need to post an issue.
Frank Cohen, 2023
[Reflections Project](https://github.com/frankcohen/ReflectionsOS)
ESP32-S3 SPI Nand/SD SdFat Format for Fat16 recipe
frankcohen
