In my application I need to measure the time between 2 events using 2 photogates. I am thinking at the following scenario:
1. When the first photogate is activated an interrupt is triggered and the timer is started.
2. If for a given amount of time the second interrupt is not triggered raised an error
3. When the second photogate is activated a second interrupt is triggered and the timer is stopped.
4. Calculate the speed based on the distance between photogates, calculate where the object will be aster a given amount of time and consider also the time needed for calculations.
5. Toggle a GPIO after the calculated time.
Questions:
1. How do I link the Timer to the GPIO's configured as external interrupts?
2. Ho can I measure the execution time of a function or a code block?
Thank you for your support,
Ion
Timers and interrupts
MicroController
Re: Timers and interrupts
What's the size of the timespans in question? What accuracy/resolution is required?
Users browsing this forum: Bing [Bot], meta-externalagent and 3 guests
