(I am beginner I am study the code...)
in file av_stream_hal_audio.c
static audio_board_handle_t i2s_device_init(uint32_t sample_rate)
i2s_driver_init(I2S_DEFAULT_PORT, sample_rate, I2S_CHANNELS); //^^^!
but
int av_stream_audio_read(char *buf, int len, TickType_t wait_time, bool uac_en)
int ret = ESP_FAIL;
size_t bytes_read = 0;
if (uac_en) {
// TODO
// ret = uac_mic_streaming_read(buf, len, &bytes_read, wait_time);
// if (ret != ESP_OK) {
// ESP_LOGE(TAG, "uac read failed");
return ret;
ret = i2s_read(CODEC_ADC_I2S_PORT, buf, len, &bytes_read, wait_time);Second problem file av_stream.c function _audio_enc
static void _audio_enc(void* pv)
av_stream_handle_t av_stream = (av_stream_handle_t) pv;
xEventGroupClearBits(av_stream->aenc_state, ENCODER_STOPPED_BIT);
char *frame_buf = NULL;
int len = 0, timeout = 25 / portTICK_PERIOD_MS;
int16_t *g711_buffer_16 = NULL;
if (av_stream->config.acodec_type == AV_ACODEC_AAC_LC) {
frame_buf = jpeg_malloc_align(AUDIO_MAX_SIZE, 16);
frame_buf = audio_calloc(1, AUDIO_MAX_SIZE);
g711_buffer_16 = (int16_t *)(frame_buf);
AUDIO_NULL_CHECK(TAG, frame_buf, return);
while (av_stream->aenc_run) {
int read_len = raw_stream_read(av_stream->audio_enc_read, frame_buf, av_stream->config.hal.audio_framesize);
if (read_len == AEL_IO_TIMEOUT) {
continue;
} else if (read_len < 0) {
av_stream_frame_t enc;
enc.len = read_len;
enc.data = audio_calloc(1, AUDIO_MAX_SIZE);
AUDIO_NULL_CHECK(TAG, enc.data, break);
av_stream->audio_pos += enc.len;
enc.pts = (av_stream->audio_pos * 1000) / (av_stream->config.hal.audio_samplerate * 1 * 16 / 8);
switch ((int)av_stream->config.acodec_type) {
case AV_ACODEC_PCM:
case AV_ACODEC_AAC_LC:
esp_aac_enc_process(av_stream->aac_enc, (uint8_t *)frame_buf, enc.len, enc.data, &len);
enc.len = len;
timeout = 0;
case AV_ACODEC_G711A:
for (int i = 0; i < enc.len; i++) {
enc.data[i] = esp_g711a_encode(g711_buffer_16[i]);
enc.len = enc.len/2;
case AV_ACODEC_G711U:
enc.data[i] = esp_g711u_encode(g711_buffer_16[i]);
if (xQueueSend(av_stream->aenc_queue, &enc, timeout) != pdTRUE) {
ESP_LOGD(TAG, "send aenc buf queue timeout !");
free(enc.data);
ESP_LOGI(TAG, "_audio_enc task stoped");
jpeg_free_align(frame_buf);
free(frame_buf);
xEventGroupSetBits(av_stream->aenc_state, ENCODER_STOPPED_BIT);
vTaskDelete(NULL);
}I think AV_ACODEC_PCM must copy frame_buf in enc_data
