I am working on a project running on ESP-C3-13 module that read analog data from voltage splitter. The value is reading 4096 even voltage level is at 2.95v. I assure you that voltage level at pin is correct. What may cause the problem?
Thank you for your support.
Orkun Gedik
GPIO4 analogread at 4095 all the time
Re: GPIO4 analogread at 4095 all the time
Hi folks,
The reason is ADC_ATTEN_DB_11 0 mV ~ 2500 mV.
Best regards,
Orkun Gedik
Best regards,
Orkun Gedik
Users browsing this forum: Applebot, Bytespider, ChatGPT-User and 1 guest
