Page 1 of 2
_FS_LOCK makes f_open return error in IDF 3.0
Posted: Thu Nov 23, 2017 1:05 am
by abcdcadb
when I use f_open to open a file in sd card, it returns error (16) (if _FS_LOCK is a positive number (10))
FR_LOCKED, /* (16) The operation is rejected according to the file sharing policy */
if I down _FS_LOCK to 0, i can open file well, but there are several other problems.
Can anyone tell me how I keep _FS_LOCK is 10 and work well with file?, like in IDF 2.0. I dont know what were changed in IDF 3.0?
Re: _FS_LOCK makes f_open return error in IDF 3.0
Posted: Thu Nov 23, 2017 2:43 am
by igrr
This error indicates that your program is performing two operations on the same file in parallel.
When _FS_LOCK is 0, fatfs will not check for such access issues, but as you noted there will be issues later on.
Posted: Thu Nov 23, 2017 2:46 am
by kolban
Howdy,
I'm assuming by "f_open" you mean "fopen()" as in
http://man7.org/linux/man-pages/man3/fopen.3.html
fopen() returns a file pointer, so I am assuming that fopen() is returning NULL and that errno is set to 16 as per your description.
The errno 16 (decimal) is defined here:
https://github.com/espressif/esp-idf/bl ... rrno.h#L48
as EBUSY.
I'm not familiar with the notion of "_FS_LOCK". Would you be able to elaborate on this and ideally provide a link to the relevant documentation?
Posted: Thu Nov 23, 2017 3:16 am
by abcdcadb
Hi ESP_igrr
my _FS_LOCK is 10 (and even I changed it into 100), does it still mean "two operations on the same file" causes that error (or it should be 10)?
Hi Kolban,
f_write belongs to fatfs library, fwrite is stdio (newlib/include/stdio.h).
while f_write handle on "FIL"(declared on ff.h), fwrite is on "FILE", FILE is an opaque data type, i don't know they are similar or not
Posted: Thu Nov 23, 2017 4:26 am
by igrr
Ok, does the application actually open the same file twice, or tries to do something with a file (rename, copy, etc) while it is open?
The value of _FS_LOCK affects the number of files which can be checked for invalid simultaneous access. Setting it to 10 or to 100 should make no difference if you are only working with a few files.
Posted: Thu Nov 23, 2017 6:43 am
by abcdcadb
is there any way to check that I am opening the same file twice?
my code now is bulky so i am not sure. However, it works in IDF 2.0 therefore I guess it should be OK
Posted: Thu Nov 23, 2017 7:42 am
by igrr
You can figure out whether you have concurrent operations on the same file by reviewing your code, or logging your file operations, or writing wrappers for f_open and f_close functions.
IIRC, in IDF 2.0 _FS_LOCK was set to 0, which is why you didn't get any errors reported.
Posted: Thu Nov 23, 2017 8:01 am
by abcdcadb
thanks, I will
in IDF 2.0, I try setting _FS_LOCK 10, and with the same code, it still works without problem. Is there any more reason?
Posted: Thu Nov 23, 2017 8:24 am
by igrr
Perhaps when you build your application against 2.0, concurrent access to the same file does not happen, so no error is reported?
Posted: Fri Nov 24, 2017 3:23 am
by abcdcadb
ESP_igrr
could you give me an example which use f_open to open a file and then do any handling (read or write) to that file which you are sure that it works on IDF3.0?
the sd_card example uses fopen (stdio.h) not f_open.
I really need a reference now
thanks
