Issue with ESP-ADC Continuous Conversion - Abort() Exception
temuko
Postby temuko » Sun Dec 03, 2023 9:35 pm
Hello everyone,
I'm new to ESP development and currently working on a project where I need to read values from the ADC and send them via UART. I've encountered an issue with ADC conversion, and although I've tried to adapt examples from esp-idf, I'm unsure where the error might be in my code.
Code: Untitled.c Select all
#include <string.h>
#include <stdio.h>
#include "esp_log.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "esp_adc/adc_continuous.h"
#include "adc_reader.h" // Debes definir adc_reader.h con las estructuras y funciones necesarias.
#include "sdkconfig.h"
#define ADC_UNIT ADC_UNIT_1
#define _ADC_UNIT_STR(unit) #unit
#define ADC_UNIT_STR(unit) _ADC_UNIT_STR(unit)
#define ADC_CONV_MODE ADC_CONV_SINGLE_UNIT_1
#define ADC_ATTEN ADC_ATTEN_DB_0
#define ADC_BIT_WIDTH SOC_ADC_DIGI_MAX_BITWIDTH
#define ADC_OUTPUT_TYPE ADC_DIGI_OUTPUT_FORMAT_TYPE1
#define ADC_GET_CHANNEL(p_data) ((p_data)->type1.channel)
#define ADC_GET_DATA(p_data) ((p_data)->type1.data)
// prueba git
#define READ_LEN 256
static adc_channel_t channel[1] = {ADC_CHANNEL_0};
static const char *TAG = "ADC_READ";
static TaskHandle_t s_task_handle;
static adc_continuous_handle_t handle = NULL;
static bool IRAM_ATTR s_conv_done_cb(adc_continuous_handle_t handle, const adc_continuous_evt_data_t *edata, void *user_data)
BaseType_t mustYield = pdFALSE;
// Notify that ADC continuous driver has done enough number of conversions
if (s_task_handle != NULL) {
vTaskNotifyGiveFromISR(s_task_handle, &mustYield);
ESP_LOGI(TAG, "ADC Conversion done");
return (mustYield == pdTRUE);
void adc_reader_init(void)
adc_continuous_handle_t handle_init = NULL;
uint8_t channel_num = 1;
adc_continuous_handle_cfg_t adc_config = {
.max_store_buf_size = 1024,
.conv_frame_size = READ_LEN,
ESP_ERROR_CHECK(adc_continuous_new_handle(&adc_config, &handle_init));
adc_continuous_config_t dig_cfg = {
.sample_freq_hz = 20*1000,
.conv_mode = ADC_CONV_MODE,
.format = ADC_OUTPUT_TYPE,
adc_digi_pattern_config_t adc_pattern[SOC_ADC_PATT_LEN_MAX] = {0};
dig_cfg.pattern_num = channel_num;
for (int i = 0; i < channel_num; i++) {
adc_pattern[i].atten = ADC_ATTEN;
adc_pattern[i].channel = channel[i] & 0x7;
adc_pattern[i].unit = ADC_UNIT;
adc_pattern[i].bit_width = ADC_BIT_WIDTH;
ESP_LOGI(TAG, "adc_pattern[%d].atten is :%"PRIx8, i, adc_pattern[i].atten);
ESP_LOGI(TAG, "adc_pattern[%d].channel is :%"PRIx8, i, adc_pattern[i].channel);
ESP_LOGI(TAG, "adc_pattern[%d].unit is :%"PRIx8, i, adc_pattern[i].unit);
dig_cfg.adc_pattern = adc_pattern;
ESP_ERROR_CHECK(adc_continuous_config(handle_init, &dig_cfg));
ESP_LOGI(TAG, "ADC Reader Initialized");
handle = handle_init;
uint32_t adc_reader_read(void)
esp_err_t ret;
uint32_t ret_num = 0;
uint8_t result[READ_LEN] = {0};
memset(result, 0xcc, READ_LEN);
s_task_handle = xTaskGetCurrentTaskHandle();
adc_continuous_evt_cbs_t cbs = {
.on_conv_done = s_conv_done_cb,
ESP_ERROR_CHECK(adc_continuous_register_event_callbacks(handle, &cbs, NULL));
ESP_LOGI(TAG, "Starting ADC conversion");
ESP_ERROR_CHECK(adc_continuous_start(handle));
ESP_LOGI(TAG, "ADC started");
ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
ESP_LOGI(TAG, "ulTaskNotify");
char unit[] = ADC_UNIT_STR(ADC_UNIT);
ret = adc_continuous_read(handle, result, READ_LEN, &ret_num, 0);
ESP_LOGI(TAG, "read_data");
if (ret == ESP_OK) {
ESP_LOGI("TASK", "ret is %x, ret_num is %"PRIu32" bytes", ret, ret_num);
for (int i = 0; i < ret_num; i += SOC_ADC_DIGI_RESULT_BYTES) {
adc_digi_output_data_t *p = (void*)&result[i];
uint32_t chan_num = ADC_GET_CHANNEL(p);
uint32_t data = ADC_GET_DATA(p);
/* Check the channel number validation, the data is invalid if the channel num exceed the maximum channel */
if (chan_num < SOC_ADC_CHANNEL_NUM(ADC_UNIT)) {
//ESP_LOGI(TAG, "Unit: %s, Channel: %"PRIu32", Value: %"PRIx32, unit, chan_num, data);
return data;
//ESP_LOGW(TAG, "Invalid data [%s_%"PRIu32"_%"PRIx32"]", unit, chan_num, data);
* Because printing is slow, so every time you call `ulTaskNotifyTake`, it will immediately return.
* To avoid a task watchdog timeout, add a delay here. When you replace the way you process the data,
* usually you don't need this delay (as this task will block for a while).
vTaskDelay(1);
} else if (ret == ESP_ERR_TIMEOUT) {
//We try to read `READ_LEN` until API returns timeout, which means there's no available data
return 0;
return 0;
//ESP_ERROR_CHECK(adc_continuous_stop(handle));
//ESP_ERROR_CHECK(adc_continuous_deinit(handle));
My code compiles and runs, but I encounter an abort() exception. I've reviewed the code and ADC configurations, but haven't identified the issue. I'm also attaching the exception backtrace for further reference.
Code: Untitled.txt Select all
V (1689) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1689) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0x40E
D (1699) intr_alloc: Connected src 32 to int 17 (cpu 0)
I (1699) ADC_READ: adc_pattern[0].atten is :0
I (1709) ADC_READ: adc_pattern[0].channel is :0
I (1709) ADC_READ: adc_pattern[0].unit is :0
I (1719) gpio: GPIO[36]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1729) ADC_READ: ADC Reader Initialized
I (1729) ADC_READ: Starting ADC conversion
abort() was called at PC 0x40082cc7 on core 0
Backtrace: 0x40081852:0x3ffb07e0 0x40086781:0x3ffb0800 0x4008bc76:0x3ffb0820 0x40082cc7:0x3ffb0890 0x40082e05:0x3ffb08c0 0x40082e7e:0x3ffb08e0 0x400e174a:0x3ffb0910 0x400e48b9:0x3ffb0c30 0x400ec0f9:0x3ffb0c60 0x4008bb29:0x3ffb0c90 0x40083295:0x3ffb0ce0 0x400846c9:0x3ffb0d10 0x40084720:0x3ffb0d50 0x40082ab9:0x3ffb0d70 0x4008489b:0x3ffb53a0 0x400d230f:0x3ffb53c0 0x4008780e:0x3ffb53e0 0x40088d61:0x3ffb5400
ELF file SHA256: dc14c757f9a86e5f
Rebooting...
ets Jul 29 2019 12:21:46
I'm usinig the ESP32 WROOVER-E and the last esp-idf version. I would greatly appreciate any advice or insights from the community. If anyone has experienced a similar issue with ADC operations or has recommendations for troubleshooting, your input would be invaluable.
I appreciate any help or guidance you can provide!
Re: Issue with ESP-ADC Continuous Conversion - Abort() Exception
Postby Sprite » Mon Dec 04, 2023 1:38 am
Can you decode that backtrace? In esp-idf, the easiest way is to use 'idf.py monitor' as your serial terminal, it'll automatically decode it.
temuko
Postby temuko » Wed Dec 06, 2023 1:00 pm
Thank you. This is what appears with the decoded backtrace:
Backtrace: 0x4008182a:0x3ffb07e0 0x40086709:0x3ffb0800 0x4008bbfe:0x3ffb0820 0x40082c9f:0x3ffb0890 0x40082ddd:0x3ffb08c0 0x40082e56:0x3ffb08e0 0x400ddb7a:0x3ffb0910 0x400e0ce9:0x3ffb0c30 0x400e8529:0x3ffb0c60 0x4008bab1:0x3ffb0c90 0x40083271:0x3ffb0ce0 0x40084651:0x3ffb0d10 0x400846a8:0x3ffb0d50 0x40082a91:0x3ffb0d70 0x40084823:0x3ffb52c0 0x400d21ab:0x3ffb52e0 0x40087796:0x3ffb5300 0x40088ce9:0x3ffb5320
0x4008182a: panic_abort at /home/xae/esp/esp-idf/components/esp_system/panic.c:452
0x40086709: esp_system_abort at /home/xae/esp/esp-idf/components/esp_system/port/esp_system_chip.c:84
0x4008bbfe: abort at /home/xae/esp/esp-idf/components/newlib/abort.c:38
0x40082c9f: lock_acquire_generic at /home/xae/esp/esp-idf/components/newlib/locks.c:130
0x40082ddd: _lock_acquire_recursive at /home/xae/esp/esp-idf/components/newlib/locks.c:158
0x40082e56: __retarget_lock_acquire_recursive at /home/xae/esp/esp-idf/components/newlib/locks.c:314
0x400ddb7a: _vfprintf_r at /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vfprintf.c:849 (discriminator 2)
0x400e0ce9: vprintf at /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vprintf.c:34 (discriminator 5)
0x400e8529: esp_log_writev at /home/xae/esp/esp-idf/components/log/log.c:200
0x4008bab1: esp_log_write at /home/xae/esp/esp-idf/components/log/log.c:210
0x40083271: s_conv_done_cb at /home/xae/tfg_codes/ecg_source_code/main/adc_reader.c:43 (discriminator 13)
0x40084651: s_adc_dma_intr at /home/xae/esp/esp-idf/components/esp_adc/adc_continuous.c:310
0x400846a8: adc_dma_intr_handler at /home/xae/esp/esp-idf/components/esp_adc/adc_continuous.c:278
0x40082a91: _xt_lowint1 at /home/xae/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/xtensa_vectors.S:1236
0x40084823: xt_utils_wait_for_intr at /home/xae/esp/esp-idf/components/xtensa/include/xt_utils.h:81
 (inlined by) esp_cpu_wait_for_intr at /home/xae/esp/esp-idf/components/esp_hw_support/cpu.c:111
0x400d21ab: esp_vApplicationIdleHook at /home/xae/esp/esp-idf/components/esp_system/freertos_hooks.c:59
0x40087796: prvIdleTask at /home/xae/esp/esp-idf/components/freertos/FreeRTOS-Kernel/tasks.c:4327 (discriminator 1)
0x40088ce9: vPortTaskWrapper at /home/xae/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
ELF file SHA256: b3e6b852ac5caad2
Postby Sprite » Thu Dec 07, 2023 1:04 am
Thank you. You seem to be doing some kind of log command in s_conv_done_cb. That callback is done in interrupt context, and there are not that many API calls that are allowed to be done in such a context; calling the standard log functions (or anything that uses the printf family) is not one of them. That is causing the abort. You can try to use ESP_EARLY_LOG() instead; that is allowed to be called form interrupt context.
temuko
Postby temuko » Fri Dec 08, 2023 9:56 pm
Thank you!
I've resolved the issue. I encountered additional problems because I wasn't stopping the ADC after the first reading, which led to errors afterward. The ESP_LOGI was another issue when I attempted to debug the initial one.
Appreciate the assistance!
