ESP32 WROOM 32 crashes when exiting function
zapp123
Postby zapp123 » Sat Dec 23, 2023 6:29 pm
Hi there.
I have an ESP32 WROOM 32 devkit 1 and I am trying to use the Capacitive Touch sensors built into the ESP
I have some code which waits for touch to be detected, and once it is detected, it should return that the pad has been touched, instead it crashes and reboots.
Does anyone know why and what might be causing this behavior?
Code below
#define Threshold 40
int touchPad;
bool touchDetected = false;
int flag = 0;
int i = 0;
  delay(1000); // give me time to bring up serial monitor
  Serial.println("Booting");
  touchAttachInterrupt(T0, gotTouch0, Threshold);
  touchAttachInterrupt(T3, gotTouch3, Threshold);
  touchAttachInterrupt(T4, gotTouch4, Threshold);
  touchAttachInterrupt(T5, gotTouch5, Threshold);
  touchAttachInterrupt(T6, gotTouch6, Threshold);
  touchAttachInterrupt(T7, gotTouch7, Threshold);
  touchAttachInterrupt(T8, gotTouch8, Threshold);
  touchAttachInterrupt(T9, gotTouch9, Threshold);
void loop(){
  if(touchDetected){ //Check continuously if any touch is detected
    switch(touchPad){
      case 0  : Serial.println("Case 0 Selected"); delay(1000); break;
      case 3  : Serial.println("Case 3 Selected"); break;
      case 4  : Serial.println("Case 4 Selected"); break;
      case 5  : Serial.println("Case 5 Selected"); break;
      case 6  : Serial.println("Case 6 Selected"); break;
      case 7  : Serial.println("Case 7 Selected"); break;
      case 8  : Serial.println("Case 8 Selected"); break;
      case 9  : Serial.println("Case 9 Selected"); break;
      default : break;
      delay(1000);
void gotTouch0(){
 Serial.println("Got 0");
 touchDetected = true;
 Serial.println("Changed TouchDetected to True");
 touchPad = 0;
 Serial.println("Set TouchPad to True");
 delay(5000);
 Serial.println("Going Back");
void gotTouch3(){
 Serial.println("Got 3");
 touchPad = 3;
 delay(500);
void gotTouch4(){
 Serial.println("Got 4");
 touchPad = 4;
 delay(500);
void gotTouch5(){
 Serial.println("Got 5");
 touchPad = 5;
 delay(500);
void gotTouch6(){
 Serial.println("Got 6");
 touchPad = 6;
 delay(500);
void gotTouch7(){
 Serial.println("Got 7");
 touchPad = 7;
 delay(500);
void gotTouch8(){
 Serial.println("Got 8");
 touchPad = 8;
 delay(500);
void gotTouch9(){
 Serial.println("Got 9");
 touchPad = 9;
 delay(500);
Basalt
Re: ESP32 WROOM 32 crashes when exiting function
Postby Basalt » Sun Dec 24, 2023 12:52 pm
I never used the Touch functions myself, but I do notice some issues with your code:
- using delay() in an interrupt function is generally a bad idea
- you don't reset touchDetected to false again
Have a look at some examples:
https://espressif-docs.readthedocs-host ... touch.html
lbernstone
Postby lbernstone » Sun Dec 24, 2023 5:31 pm
The delay in your loop is not in the right place. It should be at the very end of the loop in order to debounce the switches and allow other tasks cpu time.
If it is crashing with no error, then you probably have a power problem.
zapp123
Postby zapp123 » Mon Dec 25, 2023 12:40 pm
Thank you guys! Issue was resolved by moving the delays. The flag change was necessary to reset and wait for another interrupt. it works fine now :)
Users browsing this forum: Bytespider, PerplexityBot and 259 guests
