ESP32 not waking up from deep sleep anymore
Posted: Mon Dec 25, 2023 4:17 pm
Hello. I built a tank level sensor with the ESP32 (D1 mini board) and a TOF sensor. To have it run only once a day on low power, I used deep sleep with RTC timer wakeup function and RTC GPIO pins to trigger the low power mode of the TOF module.
This worked out with timer set to 1 hour for testing, but I measured the current and found it was still a bit high, so I added some lines of code I read in a tutorial for hibernation mode. The sleep routine looked like this:
It did not really work out, as it did not wake up the Module anymore. Strangely enough now after I reverted to the previous code it does not wake up either!
So my question is: Is it possible to somehow "break" the RTC wakeup timer function by software or by some hardware issue I may have accidentially caused? The other functions all work out, the module still can use Wifi and TOF and send the data, just the sleep mode function is now broken. I tried to flash it with a demo code for RTC deep sleep that is in the Arduino IDE, removed all cennections to the Di module but this also does not reboot.
What did I do wrong and is there a way to fix it or do I need to use a fresh module and just not use those supposed hibernation functions?
Thank you
void startDeepSleep(){
delay(1000); //wait a moment before sleeping
Serial.print("hibernating for [microseconds]:");
Serial.println(uint64_t(TIME_TO_SLEEP) * uS_TO_S_FACTOR);
Serial.flush();
// keep xshut pin low to sleep TOF
rtc_gpio_set_level(xsleepPin, 0);
rtc_gpio_hold_en(xsleepPin);
// wakeup by timer
esp_sleep_enable_timer_wakeup(uint64_t(TIME_TO_SLEEP) * uS_TO_S_FACTOR);
esp_deep_sleep_start();
}Code: Select all
Serial.flush();
// hibernate to conserve energy
esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_SLOW_MEM, ESP_PD_OPTION_OFF);
esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_FAST_MEM, ESP_PD_OPTION_OFF);
esp_sleep_pd_config(ESP_PD_DOMAIN_XTAL, ESP_PD_OPTION_OFF);
// wakeup by timer
}So my question is: Is it possible to somehow "break" the RTC wakeup timer function by software or by some hardware issue I may have accidentially caused? The other functions all work out, the module still can use Wifi and TOF and send the data, just the sleep mode function is now broken. I tried to flash it with a demo code for RTC deep sleep that is in the Arduino IDE, removed all cennections to the Di module but this also does not reboot.
Simple Deep Sleep with Timer Wake Up
ESP32 offers a deep sleep mode for effective power
saving as power is an important factor for IoT
applications. In this mode CPUs, most of the RAM,
and all the digital peripherals which are clocked
from APB_CLK are powered off. The only parts of
the chip which can still be powered on are:
RTC controller, RTC peripherals ,and RTC memories
This code displays the most basic deep sleep with
a timer to wake it up and how to store data in
RTC memory to use it over reboots
This code is under Public Domain License.
Author:
Pranav Cherukupalli <cherukupallip@gmail.com>
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 5 /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
esp_sleep_wakeup_cause_t wakeup_reason;
wakeup_reason = esp_sleep_get_wakeup_cause();
switch(wakeup_reason)
case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
void setup(){
Serial.begin(9600);
delay(1000); //Take some time to open up the Serial Monitor
//Increment boot number and print it every reboot
++bootCount;
Serial.println("Boot number: " + String(bootCount));
//Print the wakeup reason for ESP32
print_wakeup_reason();
First we configure the wake up source
We set our ESP32 to wake up every 5 seconds
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
" Seconds");
Next we decide what all peripherals to shut down/keep on
By default, ESP32 will automatically power down the peripherals
not needed by the wakeup source, but if you want to be a poweruser
this is for you. Read in detail at the API docs
http://esp-idf.readthedocs.io/en/latest/api-reference/system/deep_sleep.html
Left the line commented as an example of how to configure peripherals.
The line below turns off all RTC peripherals in deep sleep.
//esp_deep_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
//Serial.println("Configured all RTC Peripherals to be powered down in sleep");
Now that we have setup a wake cause and if needed setup the
peripherals state in deep sleep, we can now start going to
deep sleep.
In the case that no wake up sources were provided but deep
sleep was started, it will sleep forever unless hardware
reset occurs.
Serial.println("Going to sleep now");
delay(1000);
Serial.flush();
Serial.println("This will never be printed");
void loop(){
//This is not going to be called
}Thank you
